Need help on engine harness terminals
Old Feb 19, 2011 | 11:09 PM
nitewolf's Avatar
Default Need help on engine harness terminals
I noticed on my 90 si engine harness some wires where broke. Dizzy wires , blk/ylw and blue also the started wire blk/wht.
There broke off right at the terminal. I would like to know where I could get the termanils at. I tried bkhonda and acuraoemparys.com. I haven't tried the local dealership. I get off work at 6 Monday-Saturday and there closed.
Old Feb 20, 2011 | 03:01 AM
radex7's Avatar
Default Re: Need help on engine harness terminals
Man, go to your nearest junkyard with a pair of pliers in your pocket, find a honda, anything from 1988 to at least 1995 will do, clip necessary pigtails, de-pin those, and finally splice them in place of your busted ones. Soldering and heat shrinking your connections is preferable, but in a pinch - butt splices will do. There is only a few variations of terminal on your honda.
If you are not in a hurry pm me your address and I will send you some wire ends with pins.
Old Feb 20, 2011 | 09:12 AM
crx_si-r's Avatar
he is probably like me, i dont like to add close to 20yr old parts that go bad back on my car. OP PM me, i make engine harness with all new terminals n materials. the only thing i re-use on my harnesses are the actual plastic connectors. took me months and months of searching to find correct terminals. i have a gang load of each one, pm me
or feel free to txt me
916-541-5266
Old Feb 20, 2011 | 09:17 AM
radex7's Avatar
crx_si-r! This is awesome. I cannot tell you how many times I poked myself trying to spread the crimpers on those buggers! For future reference, would you be willing to distribute those?
OP ^^^ this is the way to the cleanest solution.
Old Feb 20, 2011 | 09:31 AM
crx_si-r's Avatar
i have a bunch that i ordered (they take me about 2 weeks to get them once i place an order). as long as i dont run out i can sell them. txt me what you need and i can quote you a price (assuming i have enough o what you need). lmk
Old Feb 20, 2011 | 12:35 PM
nitewolf's Avatar
I made my own harness also, I need the pins/terminals that go on the plug that plugs into the cabin harness, I can't really explain it but I could upload pics, I just need 3 male terminals. I tried using the 3 wires from a eg but there different terminals.
Old Feb 20, 2011 | 01:21 PM
crx_si-r's Avatar
Post pics of the original ones. I'm pretty sure I have them. Or txt pics to me at my cell above.
Old Feb 20, 2011 | 05:36 PM
n/a2boost's Avatar
crx_si-r do you have the big pins for the obd2 dizzy plug and the small pins for the alt for obd2?
Old Feb 20, 2011 | 07:07 PM
crx_si-r's Avatar
i might. im almost 90% sure i have the alternator pins, but not positive on the distributor pins. can you de-pin yours and post a pic. and ill check my stock.
Old Feb 20, 2011 | 07:29 PM
n/a2boost's Avatar
here are the obd2 dizzy and alt pins..
[IMG] Uploaded with ImageShack.us[/IMG]
Old Feb 20, 2011 | 07:39 PM
crx_si-r's Avatar
i might have them, gimme a couple minutes to check
Old Feb 20, 2011 | 07:50 PM
crx_si-r's Avatar
your in luck, i do have them.
Old Feb 20, 2011 | 07:55 PM
n/a2boost's Avatar
how much you looking to get for them?
Old Feb 20, 2011 | 07:58 PM
crx_si-r's Avatar
txt me, or pm. once prices are discussed this will get locked
Bob Nealey
15
Nov 29, 2015 07:30 AM
nuts91civic
Apr 23, 2011 02:57 PM
cehcivic15
Dec 19, 2008 10:26 AM
monicle
Dec 23, 2003 02:06 PM
