anybody try 10F/10R sus ?
Old Sep 25, 2002 | 04:51 PM
yoshi234's Avatar
I shoot brides
Default anybody try 10F/10R sus ?
as some of j00 f00z may know, I've recently acquired a set of zeal b6 w/ 10kg (front) and 6kg (rear) springs. Ths is zeal's 'street set up'.
Suprisingly, this set up is no more stiffer riding than stock on the bumpy street of socal (shocks set on #1- softest). Now I haven't had the chance to really push it on the track yet, but judging from the rates they probably won't be ideal for the track.
I was thinking of changing the springs to 8F/10R or even 10F/12R, but a friend has an extra set of 10kg springs. For those that have tried various set ups, what do you think of 10F/10R?
yshi - whose car is a pig! (full interior, AC, PS, roll bar).
*for those that need std rates, 10kg/mm = 559lb/in
Old Sep 25, 2002 | 04:56 PM
MattD@Stoptech's Avatar
Default Re: anybody try 10F/10R sus ? (yoshi234)
Just dont lift, f00....
It all depends on your driving, with such high rear spring rate you better make sure you're committed to the turn....but i've allready told you that...
go for it!
Dr Pooface's Avatar
I have 400f/600r and LOVE it. I think even spring rates would push too much, but what do I know? Maybe you could balance it all out with tire pressure. I say go for it. If you don't like it it's easy enough to swap out.
Old Sep 25, 2002 | 04:57 PM
BlueR's Avatar
if 10/6 tends towards understeer
8/10 tends towards oversteer...
wouldn't 10/10 be ideal at a track with tight turns
Old Sep 25, 2002 | 04:59 PM
ZygSpeed's Avatar
Default Re: anybody try 10F/10R sus ? (El Pollo Diablo v3.5)
Actually, it might work out pretty well.
I'm planning on 12F/14KR , as soon as I find some 14 K springs!
Time to start experimenting and see waht works for y0u!
Old Sep 25, 2002 | 05:02 PM
BlueR's Avatar
Default Re: anybody try 10F/10R sus ? (Zygspeed)
ed...joo is crazy
Old Sep 25, 2002 | 05:05 PM
ITRbroham's Avatar
shit post warrior
Default Re: anybody try 10F/10R sus ? (BlueR)
Just hearing that word understeer scares me!
Old Sep 25, 2002 | 05:07 PM
ZygSpeed's Avatar
ed...joo is crazy
Am NOT!
Well .... hehe, I'm just going over to the Dark Side!
Back in Black's Avatar
Rather OG
Ditto. I may even try finding a 14k/16k setup. Either way, I'll definitely want a higher rate for the rear.
Jason-
who likes rotation, and dislikes push
Old Sep 25, 2002 | 05:10 PM
ZygSpeed's Avatar
Default Re: anybody try 10F/10R sus ? (Jason Franza)
Jason-
Well, I'm starting with the 12KF/10KR springs that come with these Buddy Clubs.
If i don't find those 14K springs soon I'll just swap them front to rear and vise versa.
Old Sep 25, 2002 | 05:12 PM
BlueR's Avatar
dayum...the roads down there are that nice huh?
Old Sep 25, 2002 | 05:13 PM
Rather OG
Remember, you're speaking to the dude the drove on A032R compounds for what, 30k miles or so?
Old Sep 25, 2002 | 05:14 PM
BlueR's Avatar
like i said... nuts
[Modified by BlueR, 9:15 PM 9/25/2002]
Old Sep 25, 2002 | 05:40 PM
Mike M's Avatar
Founding Member
Now whats wrong with that
Old Sep 25, 2002 | 05:41 PM
ZygSpeed's Avatar
lol!
Actually the roads ARE pretty good down here lately.
Even though I didn't get 30K miles out of those o32Rs, I did get two full spring/summer/fall seasons out of them (with some use of my other wheels).
Not to mention to and back from the first ITR EXPO!
Maybe I'll go the speed limit if I make the suspension stiff enough!!
[Modified by Zygspeed, 9:42 PM 9/25/2002]
Mike M's Avatar
Founding Member
Default Re: anybody try 10F/10R sus ? (Mike M)
Yoshi what Sway bar do you have in the rear? Stock, JDM ITR, Mugen?
Old Sep 25, 2002 | 05:52 PM
BlueR's Avatar
Default Re: anybody try 10F/10R sus ? (George Knighton)
a lil ot...but anyone know the srping rates of the mugen lds
Old Sep 25, 2002 | 06:00 PM
ZygSpeed's Avatar
I believe you're referring to the Low-Downs?
They're only about 100 lbs stiffer than stock in front and in back (something like 350F/330R)... not exact but I don't have the figs. anywhere.
Old Sep 25, 2002 | 06:02 PM
BlueR's Avatar
yes...the lowdowns
can't get as hardcore as you southern boys with manhole size craters up in here...
Old Sep 25, 2002 | 06:07 PM
Hacemuy's Avatar
Isn't it a bit more complicated than just "swapping out" the springs? I was under the impression that Zeal valves their shocks specifically for the spring rates you choose.
For example: The shocks would have different valving if you ordered their "street" setup with the softer spring rates as compared to their "track" setups which come with stiifer spring rates.
If this is true, then would a rebuild be required whenever spring rates are changed?
Alex - who is making some assumtions after reading the SCC article on Tein
ZygSpeed's Avatar
You just need those 22" bling blings.
Old Sep 25, 2002 | 07:04 PM
Kengs's Avatar
Mugen Lowdowns are progressive rates; I know the EK9 has the following (cause I axed)
Front: 3.8K-5.5K
Rear: 2.7K-4.0K
I would suspect DC2 rates are almost identical.
Old Sep 25, 2002 | 09:13 PM
BlueR's Avatar
can my 129lbs of tq even move those things
hehe SUV type R yo!
Kengs: really...progressive...even the fronts?
Old Sep 25, 2002 | 11:07 PM
yoshi234's Avatar
I shoot brides
stock bar
if i do put 10's in the rear, will the shock have to revalved for the 10's?
yshi - who appreciated all the suggestion given here and also received thru IMs
Old Sep 25, 2002 | 11:32 PM
Mike M's Avatar
Founding Member
I'd say find some 12k, but if you have the 10k might as well try them out
No need for revalving
