Stage 2 cam d15b2 where should i set my camgear at?
Im installing it right now its the web cam stage 2 and i got a aem cam gear so i want to know where i should have it set at? stock bottom end obd1 if that helps
Stock bottom end???? If so, you are wasting your time/money
A stage II cam is designed to make good power gains from and engine with "high" compression! It should be at least 11:1 or you are wasting your time
get a spare d series motor, use p29's ,pg6 pistons. mild head work good thin head gasket, stage 2 bisimoto cam , tune it and have fun!!!!!!! if u interested in d series motors go to www.d-series.org they have alot of info on that site
mookbooter
Oct 3, 2013 04:56 PM
xkrazyxjbrkerx75
Nov 4, 2009 10:48 PM
