hallman pro MBC
Old Feb 19, 2011 | 09:47 AM
TeggieeTuner's Avatar
Default hallman pro MBC
Me and adam hopkins go to tune my car yesterday with the boost controller and some 880cc injectors.
the boost controller seemed to work well but in 2nd gear the wastegate opened at 15-16psi then in fourth the WG did not open, and boost slowly creeped down as i stayed in it.
i have it connected in between the wg and the intake manifold, NOT the compressor housing on the turbo.
any suggestions on what might be wrong?
Old Feb 19, 2011 | 09:57 AM
Default Re: hallman pro MBC
i also remember before i hooked the bc up my boost gauge read -20vac at idle. after i hooked up the bc it was -10vac....
Old Feb 19, 2011 | 01:37 PM
1GR8EP3's Avatar
Do you have pics of how you have it installed? Sounds like its not a strong enough vac source or the mbc is not set right.
faSHOwidIT
Jan 31, 2007 03:59 PM
faSHOwidIT
Jan 31, 2007 03:51 PM
Mad Cow
Feb 24, 2005 06:12 AM
SOHC_MShue
Jan 15, 2005 05:03 PM
99silverbullet
Jan 3, 2004 06:28 PM
