00 Accord trouble starting after sitting
Old Feb 19, 2011 | 08:40 AM
nikki21's Avatar
Icon2 00 Accord trouble starting after sitting
My 00 Honda Accord has trouble starting after sitting for a long period of time. It will crank but takes about 5-10 seconds to start and once it is started it will choke and sputter for about 5 seconds then engine sounds normal and runs great. If I turn it off and then turn it back on, it starts just fine. I recently replaced the timing belt, battery, distributor, spark plugs and wires. They ran full diagnositics on it and said my fuel system looks good because there is fuel in the lines. What could this possibly be? It has been getting worse and I don't want to end up on the side of the road again like when my distributor went out.
Old Feb 19, 2011 | 12:04 PM
chikin pickle's Avatar
Default Re: 00 Accord trouble starting after sitting
Have you put fresh gas in the car?
How long was it sitting for?
Old Feb 19, 2011 | 12:30 PM
Targa250R's Avatar
be professional
Define "long period of time." A day? A week? Months?
Old Feb 19, 2011 | 08:10 PM
phootbag's Avatar
Could be an injector that is leaking ever so slightly causing a cylinder to become washed out and fuel pressure to drop over time.
Could be a leaking check valve in the fuel sending unit.
What are the environmental conditions when this happens? Does temperature alter the symptom? As asked, what is "long period of time"?
Old Feb 20, 2011 | 03:08 PM
nikki21's Avatar
It has fresh gas and it does this after sitting for two hours or more no matter what the temperature is outside.
Old Feb 20, 2011 | 03:39 PM
phootbag's Avatar
Leaking fuel injector(s), leaking fuel pump check valve. I would check fuel pressure. Also, check to see how long it takes for the fuel pressure to drop while the vehicle is sitting. If the fuel pressure drops rapidly this would indicate a faulty fuel pump check valve.
Bernard Wells
Dec 17, 2018 08:08 PM
cwarnold77
Apr 5, 2017 01:01 PM
Brandtb
Mar 29, 2016 08:50 AM
lilhatch89
Aug 11, 2010 04:44 AM
samvilay
Oct 31, 2009 02:46 PM
