ecu
Old Feb 19, 2011 | 08:23 AM
allums34's Avatar
Default ecu
can anyone tell me why my car wont start with a stock ecu. i had a chip ecu with s100 hondata but someone stole out of my car so i got a stock ecu for my car check engine come on right away and does not turn off i cant even get a code from it by the the ecu is p28 and i have b16 with basic bolt on nothing major
Old Feb 19, 2011 | 08:33 AM
grumblemarc's Avatar
The Grumpiest
Default Re: ecu
You sure it's the correct ECU? Why can't you pull the codes?
Old Feb 19, 2011 | 08:37 AM
allums34's Avatar
Default Re: ecu
yeah i had a chipped p28 in it i used the paper clip and check engine light does not blink or anything it just stays on
Old Feb 19, 2011 | 09:10 AM
HAMOTORSPORTS's Avatar
Default Re: ecu
The "stock P28" that you installed is most likely bad. That is a "solid check engine light".
Old Feb 19, 2011 | 12:55 PM
tlarimer's Avatar
Default Re: ecu
That's exactly what I was thinking, Try another known good ecu.
Old Feb 19, 2011 | 01:53 PM
allums34's Avatar
Default Re: ecu
can the ecu be repaired
Old Feb 19, 2011 | 02:22 PM
The Grumpiest
Default Re: ecu
Did you verify that the ECU is indeed bad?
Old Feb 19, 2011 | 02:33 PM
allums34's Avatar
Default Re: ecu
no i have not i will on monday
Old Feb 20, 2011 | 09:10 AM
Red_Army's Avatar
Default Re: ecu
did you know a p30 runs a b16 as it should?
a stock/unchipped p28 ecu is for a SOHC vtec.
try again.
theiazn
Engine Management and Tuning
May 26, 2014 06:17 AM
hondaEg_808
Mar 25, 2008 11:10 PM
jdmjin
Aug 31, 2007 02:04 PM
