94 Accord Ex 2.2 v tech
hi i have a 94 accord with 2.2l. K when i turn the car off and take the key out the cabin heater stays on along with the light for what setting its on and i can also use power windows when car off key out. anyone ever heard or see this before or any thoughts on what maybe the problem any help would be greatly appreciated please and thanks!
Being able to adjust the windows with the key out before you open the door is normal. Never come across the cabin heater fan issue though.
When you open the door does the fan shut off?
lol yeah thanks man. i just realized that when i opened the door when i was out side messing with it. but still not sure about why the blower is still running tho. im thinking maybe some relay is stuck open?? but not sure of the location of the heater blower relay
The blower motor relay is the middle relay of the three in the under dash fuse/relay box. Located behind the drivers kick panel, just to the right of the foot pedals.
ok so i pulled that relay out and the blower shut off obviously but the circulation light stayed on and so did the vent light. i tapped the relay a little bit and put it back it and did the same thing. so ill get a new relay tomorrow and try that. is there like a main a/c relay or anything like that?
HELLo.. i'm john.. got a 94 accord and im planning to change the engine to V-TECH 2.2L.. is it possible? will the V-TECH technology work? how about the transmission? wiring? please help.. thank you
If you want to know about the F22B2 to F22B1 VTEC swap you could check the FAQ's.
The F22B1 engine is a direct swap if you stick to the 94-95 year (VTEC) engines. Your transmission will work. However, You will need to add the wires for the VTEC or if you don't feel like messing with wires. You could buy a 94-95 Accord Ex engine wire harness. You will also need to buy a VTEC P0A ECU from a 94-95 Accord EX. Without that VTEC won't work properly.
FYI, next time you should just start your own thread to ask your questions. This one has nothing to do with VTEC swaps.
I'm guessing that you fond this thread by doing a search for V-TECH right...lol
Benny Honda
Jul 21, 2017 04:10 PM
battle2.0ek9
18
Aug 31, 2013 05:53 PM
twentytwocpb
Jan 4, 2008 10:46 AM
aws140
Sep 5, 2005 04:11 AM
