OBD2b Integra w/obd1 ECU and jumper harness
Ok heres the situation.
When i put a chipped obd1 ecu and jumper harness in my Teg its goes into limp mode and wont rev past 2500.
I swap chips and it runs fine. I swap back to the original obd2b ecu and its fine.
So i take the first chip put it back in the ecu and run it on a obd1 car and it runs fine just high idle, but it revs way past 2500.
My question is there a wire I need to switch around? I know obd2b civics need to swap IACV wires, but Integras should be plug and play right?
also will i need to switch to a obd1 dizzy?
You don't need to switch anything. It's a direct plug and play.
You also do not need an obd1 distributor.
What motor is this? and what basemap are you using?
its a b18b1. its on chrome i believe.. all stock motor with 8psi
it works in my obd1 civic but not my obd2b teg
O my bad Crome. Ill have to check the CEL in the morning.. Do i check CELs in both cars? jss to see what comes up?
Thanks for trying to help me out.
its throwing code 6 and 36 in my obd1 civic.. but it will rev all the way no hesitation. i have to go to the other house and check the integra
ECU CODES (Thanks to Drag III Integra)
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
67 Catalyst low efficiency. (same as P0420)
70 Automatic Transmission Malfunction w/AT Controls
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Evaporative Emission Control System insufficient purge flow
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
hrmmm nothing looks like the reason it wont rev past 2500 in the my obd2b teg... it wierd cuz ill swap chips and it revs fine.. argghhhhhhh
it was throwing code 7 not 6... here is a link
My ecu codes
My ecu codes
Im just gonna swap engine and interior harnesses from a obd1 Integra I just got.. Ive done it before took me about 3 days..
