Mini Me questions... simple ....
Being that the Mini Me is the sohc version of an LSVT, does it give more Hp Tq than a straight Ex ? (I assume it would)
And is it because of a displacement difference or just to get vtec on a non vtec motor ?
Is the R/S ratio on the non vtec motor the same ?
X2
X2
what bottom end are you talking about specificially of putting the Z6 or the Y8 head on?
If you put it on a D15, the redline I believe jumps, I'm not to sure on mini-me frankensteins.
1) Depending on what your final CR is, you may or may not get more power. What I've heard is that it's about the same as a straight Z6 if done with the straight Z6 head, and a little more powerful with the Y8 yead.
2) There's no displacement difference. A6s, Z6s and Y8s all have the same displacement, 1.6L
3) Mini-me is only slapping a new head on the block - the R/S ratio is something which is stricly bottom end. In other words, R/S will not be affected.
Ok, lemme clear this up.
I thought the minime was a D15 block with a vtec head.
I know the D15 has a great R/S ratio and can rev to high heaven, but is that why it's used in a mini me, or do the pistons yield a higher CR with a Z6 head or (higher w/ Y8) ?
X2
X2
SlAmMeD 91 HaTcH
Nov 23, 2004 05:55 PM
