Looking for 96 JDM Auto Prelude ECU
What up fellas!
I've got a 96 auto SI lude, that because of the crank pulley rounding off the end of the crank, I put in a Jdm H22. (Go ahead get all the laughing out of your system. Yes I did a swap in an AUTO car!) If you are familier with the auto prelude in 96 then you know that honda combined the ECU and TCM into one unit so to get it running with the H22 I got the OBD-2 to OBD-1 down grade harness that also has the plugs for a seperate TCM. I'm running a P0F(JDM OBD-1 auto H22 ECU) I'm trying to find a 96 JDM AUTO Prelude ECU. it has to be a 96 cuz Honda didn't combine the two units in any other year. Does Honda have such an ECU? If so What is the Part number? where could I go to get one? If anyone could help me out with any of these questions I'd be grateful! The set up I'm running now sort of runs like ***!
Thanks for any help you can give
KTeller8
Feb 14, 2003 04:22 PM
