Car jerks when rolling slow
Old Feb 17, 2011 | 01:51 PM
91b18a1ls's Avatar
Default Car jerks when rolling slow
My car likes to jerk or hesitate and then pop forward when rolling in 1st and 2nd and just barley touching the gas. If i'm rolling through a parking lot or stop and go traffic when I press the gas just enough to keep the car moving it acts like its not getting any gas and then all of a sudden jerks forward. It makes me look like I dont know how to drive a stick and its really making me mad. I give it gas and it just sits there for a second and doesnt do anything and then BAM it just jerks acouple times and accels hard for a second or two. It runs fine when I'm at speed and really pushing it, has a smooth idle, and no check engine lights. It does smell like gas really bad inside my car after it does the jerking thing (like smells coming through the vents). No gas leaks that I can see and the rings on the injectors seem to be fine. The only thing I can think of is my fuel filter is bad. Any ideas guys? Thanks
Old Feb 19, 2011 | 06:59 PM
bank2me's Avatar
Default Re: Car jerks when rolling slow
That kind of sounds like what my car does. Like if I am going slowly in 1st gear and let off and press the gas a bit its like it jerks back and forward. I'm not sure whats up with mine. I thought maybe a motor mount but nothing changed when I put my B20B in and put Energy Suspension inserts in. Wierd problem.
Old Feb 19, 2011 | 07:29 PM
sixfourkiller's Avatar
you should also check your tp sensor and see if its reading right
Old Feb 19, 2011 | 07:32 PM
1998GsRIntegra's Avatar
Mine does the same thing as well. I just have to be extremely careful with the throttle in 1st at low speeds. It will jerk bad if im crusing at like 10mph or so in 1st and let off. Its annoying because I have no idea what causes it as well.
Old Feb 19, 2011 | 08:26 PM
mouab18c1's Avatar
Are you guys stock?
Old Feb 19, 2011 | 08:30 PM
Bowl_of_Rice's Avatar
mine does that too it pisses me off my cousins integra is smooth but when it comes to mine it jerks
Old Feb 19, 2011 | 08:36 PM
my car has a straight pipe welded to my cat i think its a high flow not sure dc 4-1 header with dents an intake at 119xxx miles
Old Feb 19, 2011 | 09:01 PM
mouab18c1's Avatar
I should have been clear, what ECU are you guys running in your vehicle? Stock? yada yda
Old Feb 19, 2011 | 09:39 PM
turboacurab20's Avatar
sticky throttle body or throttle cable / tps sensor broken / tune up plugs wires cap rotor / are some of the things id check first and replace fuel filter just because its good maintence
Old Feb 19, 2011 | 09:40 PM
cracker1252's Avatar
really thought this topic was something else.
im going for oil in sparkplug.
Old Feb 19, 2011 | 11:13 PM
bank2me's Avatar
Originally Posted by mouab18c1
Are you guys stock?
I have a B20B with the stock LS trans. It jerked even with my original B18A1 in my car. It's ****ing annoying.
Old Feb 19, 2011 | 11:44 PM
mouab18c1's Avatar
I see, funny thing is my original GSR motor and ecu never had this problem until my current setup.
I haven't had this issue since I installed new energy suspension motor mount inserts for my lower torque mounts.
Old Feb 19, 2011 | 11:46 PM
SiLEnT_ST's Avatar
Does sometime when your at low rpm and you gas it a lil and it just bogs and go no where? Wouldn't hurt to check or replace your spark plugs.
Old Feb 20, 2011 | 06:07 AM
Dogginator's Avatar
Daisy... Daisy...
My car does this sometimes and it is working just fine. Sometimes a resonance is established with the IACV, ECU, and drive train. Push in the clutch and let it back out and the resonance should stop. It may reinitiate if the conditions are the same.
Old Feb 20, 2011 | 06:19 AM
2kdb8's Avatar
yup, this is what i was thinking is your problem. worn torque mounts and when you give enough gas the engine jumps forward and jerks car. my car did this for a bit till i replaced a torn torque mount. still does it a little but i have inserts i have to install.
Old Feb 20, 2011 | 07:33 AM
sde780's Avatar
most hondas Ive had does this in 1st
Old Feb 20, 2011 | 10:20 AM
Are you guys stock?
Ahh not really. as far as ecu goes. p28 with a crome pro rtp board. I just did the general tune up not that long ago. spark plugs, plug wires, cap and rotor, ect.
Old Feb 20, 2011 | 10:48 AM
mouab18c1's Avatar
I was just curious cause when my car was stock it never had an issue. My brothers old stock gsr did not have this issue either. Nor does my two other cousins Integra's as well.
So I was just thinking it could be tuning related?
Old Feb 20, 2011 | 11:48 AM
koss1229's Avatar
Mine has the same issue and it gets worse now. I'm pretty sure it has something to do with fuel management and motor mounts maybe.
Very annoying
Old Feb 20, 2011 | 11:55 AM
EgChris10485's Avatar
does it have a lightened fly wheel
Old Feb 20, 2011 | 12:57 PM
2kdb8's Avatar
try putting it in 2nd and roll at like 4-5krpm and let go of gas, if you feel it jerk back pretty bad like the engine moving around its your motor mounts/torque mounts.
Old Feb 20, 2011 | 01:47 PM
the comanche's Avatar
I would like my name to be Cattinator
My old teg did this when my throttle position sensor was fubar'd. Getting a replacement was easy, screwing it down with a volt meter in it to make sure it was in the right position down to the hair was a bitch Does your car throw a CEL?
Good luck.
Old Feb 21, 2011 | 12:08 PM
Good luck.
I'm sensing a battlefield player in here. Haha
Old Feb 21, 2011 | 12:31 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
My car also does this if I'm rolling slow and close the throttle quickly. It happens more so right around the engine idle speed, so the 750 rpm idle is also trying to roll the wheels (and car) forward. The slower and gentler I close the throttle, the less it happens.
I think this is just a characteristic of manual transmission cars. It's always done it, and my old car did the same. I've put over 200K miles on my car since I bought it so I don't really worry about it too much.
Old Feb 21, 2011 | 02:27 PM
JDMxTai's Avatar
My old civic did that too. I always though it was something with clutch and first gear cause i could be at 500rpm in 2nd gear and not get that jerk. so it can't be Fuel related has to be tranny and clutch related
crxaddikt
14
Jun 29, 2011 04:27 AM
w4kj4k
Oct 12, 2008 01:39 PM
projsectEF
Sep 10, 2006 06:58 PM
eg6turb0
12
Jan 15, 2005 08:02 PM
eg6turb0
Jan 10, 2005 11:44 AM
