GOLDEN EAGLE MFG. RACE PROVEN PRODUCTS
‘’SAVE YOUR ENGINE’’
DO NOT USE CHEAP IMITATION VTEC KITS.
YOU CAN BLOW OR SEVERLY DAMAGE YOUR ENGINE
BY NOT HAVING ENOUGH OIL FLOW UP TO THE HEAD.
THE # 1 CYLINDER WILL OVER HEAT AND MAY CAUSE
YOU TO DAMAGE,CRACK, YOUR HEAD OR SLEEVE.
GOLDEN EAGLE VTEC KIT IS THE ONLY WAY TO GO!
OUR OIL FEED HOSE IS ALMOST TWICE THE INSIDE
DIAMETER AS THE CHEAP IMITATION BRANDS HOSE.
OUR SANDWICH PLATE OIL FEED THREADED ADAPTER
HAS SIX HIGH FLOW CNC MACHINED PORTS. BRAND X
SHOWN IN THE PICTURES BELOW HAS ONLY FOUR
SMALL HOLES. THE OTHER BRAND SHOWN ALSO HAS
NO RETAINER CLIP.
NO RETAINER CLIP.
