The best mono amp for $400
http://www.woofersetc.com/showitem.taf?item_ID=1575
JL Audio 500/1
500watt MonoBlock Amplifier
Rated Power:
500 W RMS @ 1.5 ohm-4 ohm
(11V-14.5V)
THD at Rated Power:
<0.05% @ 4 ohm
S/N Ratio*:
>95dB below rated power
Frequency Response:
5 Hz-500 Hz (+0, -1dB)
Damping Factor:
>500 @ 4 ohm/50 Hz
Input Range:
switchable from 200mV-2V RMS
to 800mV-8V RMS
Dimensions:
13.4"L x 9.25"W x 2.36"H
Features:
Differential-Balanced Input Topology:
(1 pair of inputs)
On-board Crossover:
fully-variable (40-200 Hz),
selectable-slope LP (12 or 24 dB per octave)
Preamp Output:
2-channel (independent active filter, parallel with amp filter or full-range)
Bass EQ:
parametric with variable boost up to 15dB and Remote Bass Control (optional)
Infrasonic Filter:
fully-variable 24dB/octave from 15-60 Hz
Signal-Sensing Turn-On:
permits operation without remote lead
Dual mono speaker output connections:
accept up to 8ga. wire
+12V and Ground connections:
accept up to 4ga. Wire
$399.99
JL Audio 500/1
Rated Power:
(11V-14.5V)
THD at Rated Power:
<0.05% @ 4 ohm
S/N Ratio*:
Frequency Response:
Damping Factor:
>500 @ 4 ohm/50 Hz
Input Range:
to 800mV-8V RMS
Dimensions:
Features:
(1 pair of inputs)
On-board Crossover:
Preamp Output:
Bass EQ:
Infrasonic Filter:
$399.99
jbl bp1200.1 can be had VERY cheap over ebay and the amp rocks + you'll save some cash from the initial 4 bills.
JL, rockford bd500.1 are your only other alternatives in the same performance/price category. other than that, its all above $400.
-Rage
-Rage
