I ruined my center cap plastics, need help!
Old Feb 17, 2011 | 08:39 AM
Captain Key!s's Avatar
Default I ruined my center cap plastics, need help!
I am refinishing my wheels, (Crimson Linea Sports) and made a pretty fatal mistake. I masked off the plastic/acrylic logo on the hex center caps very well... Or so I thought...When I used aircraft stripper to get the clear coat off, a small amount seeped under my masking and ate away at the plastic. Newb mistake, I know. I wanted to separate them from the hex cap, but i could not get it off!
What are my options? I refinished my lips/hardware and they look gorgeous but these caps are disgusting. I cant have a restored wheel with these in their present condition. Any help?? Please!
Old Feb 17, 2011 | 01:06 PM
Default Re: I ruined my center cap plastics, need help!
Nobody? Who are the wheel re-finishers on here that people talk about?
Old Feb 17, 2011 | 02:23 PM
siblues's Avatar
A picture would help since I am sure they wont have an idea of how bad they are?Can they be repaired or are they past the repair stage?
Old Feb 18, 2011 | 05:37 AM
I don't have a camera at the moment. I worked on them a while last night and I honestly think that I might just have to source another full set of these caps. What a shame.
Old Feb 18, 2011 | 06:47 AM
toyomatt84's Avatar
Sanji
Are you referring to the gel-type center portion of the cap with the embossed logo set in the resin? If so, then... you may be screwed in to finding new caps or a specialty logo maker that deals with resin-embedded logos.
Old Feb 18, 2011 | 06:57 AM
r.wright's Avatar
is it on the surface or did the acid burn all the resin away? if its on the surface only then polish the emblems along w/the hex cap metal wetsanding all the way up over 1000 grit.
either way: good luck
Old Feb 18, 2011 | 07:40 AM
Yeah, its the plastic part of the cap. The stripper did not eat all the way through, just "bubbled" up the edges. Once the wet sanding is done, is there a specific polish (plastic head light polish?) to use? Thanks for the input guys, I know this idiocy on my end doesn't happen too often.
Old Feb 18, 2011 | 07:47 AM
toyomatt84's Avatar
Sanji
I don't know... you seem pretty dumb to me. (only being sarcastic, don't take offense by it)
As for the polish, I would use a plastic/glass polish at first. If that's not aggressive enough, you can try using aluminum polish.
Old Feb 18, 2011 | 08:22 AM
I'll probably see if a company can do this locally, I don't want to screw these up any more than I have already. Man this sucks...
JDM_HAMSTER
May 1, 2010 04:32 PM
hondaon18's
Mar 17, 2010 10:20 PM
mikeycivic
Jun 26, 2008 01:06 PM
hcarcrx
Mar 6, 2006 06:02 AM
