I need the drive belt numbers on the belts
Old Feb 17, 2011 | 06:26 AM
pityocamptes's Avatar
Default I need the drive belt numbers on the belts
Clown that changed my belts out looks like he swapped them on mistake. The power steering rubber mounts for the clips don't line up. The belts are honda belts. Does anyone know what the numbers are? It looks like he mixed up the a/c and ps belts. Thanks!
Old Feb 17, 2011 | 09:32 AM
Default Re: I need the drive belt numbers on the belts
Bump! I got the numbers:
PS: DY5040333 - 33.3"
ALT: DY5040315 - 31.5"
AC: DY5040323 - 32.3"
It looks as if the PS is the longer belt however, when I looked at it this morning the rubber mount for the hose between the reservoir and and pump do not line up. Neither does the hose mount/clip (bracket) area from the pump to the steering.
I will have to look at it closer tonight, but would a belt screw up cause this? Actually, now that I think about this the bracket/hose mount from the reservoir to the pump is BELOW the clip on the reservoir - so this would mean that they put one of the smaller belts on, right? Hopefully its the AC and PS belt as the alt is a PIA!!!
J9D6M
Jul 13, 2006 06:28 AM
Shaun
Feb 22, 2006 10:24 AM
litlekikr
May 7, 2004 09:44 AM
TURBOED-TEG
Jun 19, 2003 09:09 PM
Crowbar
Feb 5, 2002 08:42 AM
