92 accord front suspention/ brakes
Front end kinda wobbles on driver side and the wheel makes a light slaping sound..Then when I use my brakes the front end seems likely to shake apart. I had this problem then I had a 'mechanic' look at the car. He said I may need upper ball joints and was wanting to replace the entire brake system in the front (for $700) well anyway after he looked at it, the problem stopped all together!
Now the wobbeling tire feeling and violent 'shaking' has returned. The wobble seems to pulsate with each revolution of the wheel. If the rotor is warpped would I still feel that wobbel when I am not braking?
I am disabled and can't afford to fix anything thats not broken. Anybody shed some light on my problem? any simular experiances
I am having the same issue. In the past 3 months, I have replaced:
Lower ball joint
Outer tie rod
Rotors
Pads
I checked the tie rod by doing the 3 and 9 o'clock shake and it was some small, very small play which is very enlarged when driving
12 and 6 for the bearing: no wobble
Was wondering if it can be the inner tie rods....that's the only thing left.
Lower ball joint
Outer tie rod
Rotors
Pads
street_ride14
Jun 22, 2012 01:56 AM
iDs748
Aug 21, 2009 01:54 PM
