GSR motor help
just when i thought i was done mounting the motor in my hatch i go fill the radiator with coolant and a metal pipe in the back is leaking. its under the manifold. where does it connect to?
also idk what its called but the connecter from the radiator hose to the head. theres a L shape nipple on it. where does that connect to?
that pipe is a water pipe that connects from one side of the block to the thermostat housing. it also has 2-3 nipples on it (depending on that engine u have) that distributes water to the throttle body and/or the idle control valve on the back of the intake manifold
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/b18c1-turns-over-but-wont-start-help-2709175/
Took me 3 seconds to google it. Thank me later.
