FS: Stock Sleeve LS/VTEC BUILT motor
Honda Marketplace,
Stock Sleeve LS/VTEC Long Block FS:
Head: GSR
-Gasket Matched Port & Polished
-InlinePRO Valve Springs
-Stock Retainers
-Stock Honda Valves
-New Honda Top End gasket set
-ARP Head studs
-Cometic Head Gasket
-OEM ITR cams/stock cam gears
Block: B18A1
-Stock Sleeves bored .20 over (81.5mm)
-CP Pistons 9.0:1 compression ratio
-Eagle H-Beam Rods
-ARP Rod Bolts
-Polished crank
-ACL Rod/Main bearings
Motor was ran for 3 years and has under 2,000 miles on it. It was PROFESSIONALLY built by a machinest. From start up the motor was ran with AMS Oil 5w-40 and is changed everytime after the track. Only 1,500 road miles on her. Doesn't smoke one bit, no valve lash or anthing. Still in great running condition, I don't sell garbage parts. Some people know my name and I don't want to ruin my image at the track so help a fellow racer out and please buy this motor!
Looking for $2,200 OBO for the long block minus the intake manifold.
If anything was missed please PM me for more information, thank you.
Head: GSR
-Stock Retainers
-Stock Honda Valves
-ARP Head studs
Block: B18A1
-Eagle H-Beam Rods
-ARP Rod Bolts
-Polished crank
