225/45/15 fit on my 99-00SI Wheels?
Old Feb 16, 2011 | 11:47 AM
DeLucia's Avatar
Default 225/45/15 fit on my 99-00SI Wheels?
Im looking into buying some Toyo r888 or possibly some ventus r-s3s in a 225/45/15. This is for a 1999 si and im wondering if i can fit this on my stock SI wheels. Also will the tire rub? The car is not low at all and this is strictly for straight line. Im tired of buying drag radials and having them last 500 miles. Any input is appreciated.
Old Feb 16, 2011 | 12:06 PM
toyomatt84's Avatar
Sanji
Default Re: 225/45/15 fit on my 99-00SI Wheels?
Well, the safe wheel width range for that size tire is 7-8.5" wide. Your '99 Si wheels are only 6" wide.
Try some 225/50/15's. They are safe to be mounted on a 6" wide wheel. Plus, they are 24" in outer diameter, which is only about 0.5" taller than stock.
Old Feb 16, 2011 | 12:26 PM
DeLucia's Avatar
Thanks for the info, im not sure how weird a 50 series would look on the car I have a feeling it would rub. Anoyone have an pictures with these tires on a ek?
Old Feb 16, 2011 | 02:19 PM
DeLucia's Avatar
I think im leaning towards a 225 50 15. I just want the widest tallest tire I can fit without rubbing
Old Feb 16, 2011 | 03:51 PM
toyomatt84's Avatar
Sanji
Just the front wheels on this car:
All four on this one:
Old Feb 16, 2011 | 06:01 PM
DeLucia's Avatar
Thanks a lot. Im hoping I can hook 3rd gear at around 450whp on the street with the Toyo r888
Old Feb 16, 2011 | 06:19 PM
DeLucia's Avatar
I just found Toyo makes a 235 50 15. Anyone run this size before?
Old Feb 16, 2011 | 06:21 PM
2k.civic.si's Avatar
here is another trick to help get the tires to hook
http://www.pegasusautoracing.com/pro...p?Product=3340
Old Feb 17, 2011 | 04:34 AM
toyomatt84's Avatar
Sanji
That size will be too big for your wheels.
Old Feb 17, 2011 | 07:00 AM
Cooper The Tire Rack's Avatar
235/50-15 will not fit the OE wheels. 225/50-15 are wider and taller than recommended, but not overly so.
Old Feb 17, 2011 | 08:37 AM
DeLucia's Avatar
They recomended rim size is 6.5-8in so you sure i cant squeeze it onto my 6in wheel?
Old Feb 17, 2011 | 09:21 AM
toyomatt84's Avatar
Sanji
Safely? No.
Old Feb 17, 2011 | 10:19 AM
DeLucia's Avatar
Originally Posted by toyomatt84
Safely? No.
Whats considered safe lol what could happen?
Old Feb 17, 2011 | 10:27 AM
wannaBjdmca6's Avatar
have you tried that?
Old Feb 17, 2011 | 10:28 AM
toyomatt84's Avatar
Sanji
Sticking to the...
...recomended rim size...
Old Feb 17, 2011 | 10:29 AM
DeLucia's Avatar
no i have not, i dont know if i want that spraying all over the car
Old Feb 17, 2011 | 10:33 AM
DeLucia's Avatar
Sticking to the...
i understand that, im prolly just going to run the 225 im just curious what would happen, is the bead not going to seal on the 235 or what?
Old Feb 17, 2011 | 10:46 AM
toyomatt84's Avatar
Sanji
Any number of things could happen. It all depends on what you're doing with the car. If you're just parking it and displaying the tire setup, nothing should really happen. But, if you're looking to use the car for motorsport, I wouldn't be surprised if you had problems. But, if endangering your health for a 10mm wider contact patch (that's less then half an inch) is something you're willing to risk... don't say we didn't warn you.
Old Feb 17, 2011 | 10:55 AM
DeLucia's Avatar
Once again im not going to run the 235 it was just a question. Although i would not just be doing it for the contact patch, i wanted a taller tire, so hmm maybe risking my life is worth it now
Old Feb 17, 2011 | 11:25 AM
toyomatt84's Avatar
Sanji
Why not try the 225/50/15's? As previously stated, they are taller then OEM sizing. And, the added benefit of staying within safety limitations is a nice bonus.
Old Feb 17, 2011 | 11:33 AM
DeLucia's Avatar
Thats exactly what im going to do sir Any idea where i can get the best price on 2?
Old Feb 17, 2011 | 11:41 AM
toyomatt84's Avatar
Sanji
My first stop for tire prices always seems to be Tire Rack, due to my success with shopping there in the past. I hear Discount Tires Direct is also good, but I have no personal experience there.
Old Feb 17, 2011 | 11:43 AM
DeLucia's Avatar
tire rack doesnt sell toyo so ill have to try Discount tire direct
hondapeeler
Dec 2, 2010 08:59 AM
Ek00fbp
Jul 26, 2004 07:17 AM
vuthe32
Feb 27, 2004 09:05 PM
SantaCruz92Si
Jul 22, 2003 01:36 PM
NONKonformyst
Jan 11, 2003 08:08 AM
