whistling sound?
Old Feb 16, 2011 | 11:01 AM
killa69er's Avatar
Default whistling sound?
Okay so my 91 civic is making a whistling sound under light acceleration I haven't heard it while I'm sittin at idle but it's very annoying as a drive has anyone ever encountered this problem I need help tracking it down any help would be appreciated
Old Feb 16, 2011 | 11:21 AM
4drEF's Avatar
Keyboard Humorist
Default Re: whistling sound?
Bubb Rubb?
Does it only do it while in gear or can you hear it while coasting in neutral?
Old Feb 16, 2011 | 11:49 AM
VAZQU3Z90R3X's Avatar
Dude its Normal i bet you have a cheap filter on ur intake right? anyways just upgrade to a name brand filter like aem or k&n and problem solved Good Luck..
Old Feb 16, 2011 | 11:52 AM
KINGVEM^^ED6's Avatar
damn thats harsh for ur first post^
if u dont have a aftermarket intake
check the hose going from the head to the intake tube
mine was doing the same **** last week
Old Feb 16, 2011 | 11:59 AM
HARSHH DOGG LIKE BUNK WEED LOL BUT A SIMPLE FIXX JUST BEiNG FRANK.. PIECE iT
Old Feb 16, 2011 | 12:11 PM
nineohnine's Avatar
i got the same problem to on my ls swap never did it before the swap (with same intake/filter) but has always done it AFTER the swap... and i have no idea what it is... tho i have just learned to deal with it
Old Feb 16, 2011 | 12:29 PM
killa69er's Avatar
sorry about no to maybe details... i was posting this from my phone..
91 civic zc sohc stock air box.. and fram filter it just started this.. and it kinda sounds like its under the dash somewhere?
i bought the car from a kid that "tried" to wiretuck it and i have been routing wires and vac line and trying to get them in the right spot..
if i give it a little gas on the highway i can hear it. if i give more gas it goes away. and then also when i let off the gas it goes away as well..
Old Feb 16, 2011 | 12:41 PM
stackedhouse's Avatar
there should be a little screw on the throttle body unscrew that a little fixed my whistling problem
Old Feb 16, 2011 | 01:40 PM
LudeEFv2.4's Avatar
My old title sucked.
Hopefully you will not last long.
Old Feb 16, 2011 | 04:07 PM
99_Taco_Supreme's Avatar
Throttle body spacers make a whistling noise sometimes. You have one of those installed?
Old Feb 16, 2011 | 05:06 PM
killa69er's Avatar
no tb spacer as i said sounds like inside the car? under the dash or near the cluster
Old Feb 16, 2011 | 06:37 PM
might be ur intake mani. gasket heard that before
Old Feb 19, 2011 | 11:27 AM
91ef-si's Avatar
Unscrew the screw on the throttle body a little bit and that should fix it. But if it doesnt start checking for vacume leaks
Old Feb 19, 2011 | 03:22 PM
sde780's Avatar
inb4 "my cars idling real low help!"
it's probably your intake mine did it on my GSR and my prelude does it too. With no intake on the throttle body it still whistles
Lucman
Jun 25, 2009 09:56 AM
CrazyRexBoy
Dec 3, 2006 10:58 AM
HondaMike17
Jan 18, 2006 08:55 AM
jiggagnome
Honda S2000
22
Jan 23, 2005 03:54 PM
