how are you mounting you harnesses?
Old Feb 16, 2011 | 08:14 AM
.adam.'s Avatar
Default how are you mounting you harnesses?
i was wondering how you guys are mounting your harnesses, obviously the shoulder straps go to the harness bar, but what about the lower straps? before i just had them bolted to my seat brackets, but some of my scca friends are giving me **** for it saying they need to go to the floor with plates etc, and the nhra rulebook is pretty vague. just looking for some input......
Old Feb 16, 2011 | 08:17 AM
turtleman321's Avatar
Default Re: how are you mounting you harnesses?
4"x4" backing plate on the bottom of the car with a hole in the middle. then ran eyelets with big washers through the floor and plate then bolted them up
Old Feb 16, 2011 | 08:19 AM
Blown90hatcH's Avatar
Yup!
Old Feb 16, 2011 | 08:27 AM
.adam.'s Avatar
sounds like a plan. what thickness of plate? 1/8" like for cages? any of the harness/safety companies make like an install kit or am i better off just makin my own?
Old Feb 16, 2011 | 08:32 AM
.adam.'s Avatar
looks like gforce sells an eyebolt/washer/bolt combo for like $5, guessing i could probably hit up the hardware store and get the same for way cheaper
Old Feb 16, 2011 | 02:28 PM
boostedcivicsir's Avatar
Mr. Badwrench
shoulder harness i prefer the v, so its a single bolt in the back. crotch belt and right side are tabs and plates on the floor. the l/s use the stock belt anchor point.
Old Feb 16, 2011 | 03:10 PM
.adam.'s Avatar
is it illegal to wrap the shoulder harnesses around the harness bar? thats how ive always had em...
Old Feb 16, 2011 | 03:39 PM
SPOOLINmatt's Avatar
no but some tracks say you need something to keep them from sliding side to side like that ****in matters.
Old Feb 16, 2011 | 04:29 PM
j-bird20's Avatar
I wrap mine around the bar. Its a pain in the *** to get them the right length but once u do it ur good to go. Make sure you do it right cause with enough pressure they will loosen. Also i do have a piece of 1/4 bar in the shape of a U so they dont slide around. Im pretty sure u need to have that but we alll know how some tech guys are.
Old Feb 16, 2011 | 05:04 PM
Mr. Badwrench
it does when you have a seat that will allow the shoulder straps to spread. like a stock seat.
if you have a seat like the recaro or sparco (just pulling names out) they cant spread.
not defending the nhra, playing devils advocate.
Old Feb 16, 2011 | 05:23 PM
Bizarre's Avatar
Anybody have any pictures of their mounting points and harnesses?
Old Feb 16, 2011 | 08:31 PM
here is a link to what i used. the backing plates and eyelets both in short and long.
http://www.jegs.com/p/G-FORCE/G-FORC...53303/10002/-1
Old Feb 17, 2011 | 12:00 AM
V-SPEC 1's Avatar
that's what I use as well and works great.
Old Feb 17, 2011 | 04:20 AM
slowboy90's Avatar
now when using the mounting plates do you weld them in, just use the eyelet bolt or do you put other bolts in the plate plus the eyelet?
Old Feb 24, 2011 | 06:56 AM
MR.johnson's Avatar
yes. nhra wants both belts bolted in, 1 bolt for each strap.
Old Feb 24, 2011 | 08:50 AM
From inside the car it goes eyelet bolt, washer, floorpan, backing plate, washer, nut
NoXqcsMotosport
Oct 25, 2012 10:24 PM
meheartmycivic
Sep 2, 2009 09:46 PM
eskimo_usd
Sep 9, 2005 08:41 AM
teggytegteg
May 13, 2004 02:27 AM
Mocky57
Honda S2000
Apr 25, 2003 07:13 PM
