can an oxygen tank be used as an argon/backpurge tank?
Old Feb 16, 2011 | 08:05 AM
SQ is the SQUAD's Avatar
Default can an oxygen tank be used as an argon/backpurge tank?
i only ask because harbor freight has this tank on sale for $59 right now. it looks identical to the argon tank that is 89 its just the outlet looks to be inversed. i am assuming if i used a oxygen regulator it will work. thats if the gas place allows me to fill it with argon. the tanks thems selves are not labeled gas/oxygen.
http://www.harborfreight.com/20-cubi...der-92810.html
Old Feb 16, 2011 | 08:52 AM
TinyT's Avatar
Default Re: can an oxygen tank be used as an argon/backpurge tank?
call your gas provider
Old Feb 16, 2011 | 09:59 AM
c jackson's Avatar
threes
if you already have one tank, you could get a dual regulator and not have to worry about a second tank.
Old Feb 16, 2011 | 11:18 AM
Snow Trooper's Avatar
OG Fabricator
a tank that size will run out really fast.
i use 125s for my purge. its a worthwhile investment.
Old Feb 16, 2011 | 07:06 PM
as far as the tank size it wont get much use., until i am in a shop setting where i might use it every day this size will be ok. as far as mutliple tanks they will probe be different mixtures. tig/mig/back purge. should the backpurge be the same mixture as the tig setup?
Old Feb 16, 2011 | 08:18 PM
E-Rok's Avatar
EPIC TUNING
id just tee off of your main argon tank over using that little thing
Old Feb 16, 2011 | 08:56 PM
weiRtech's Avatar
OG Fabricator
yeah, just T off the main bottle. i don't feel there is a need for a second bottle. you can just use a small needle valve to regulate flow for the purge line. that's what i do and it works. unless you are doing purge work all the time, it isn't worth the extra rental cost as well as regulator cost.
Old Feb 16, 2011 | 09:06 PM
E-Rok's Avatar
EPIC TUNING
yea I just have one of those needle valve Y's with one port for the regulator and the other for purging
Old Feb 16, 2011 | 09:59 PM
FabChild's Avatar
You can't use the bottle anyway, Oxygen cylinders have different valves. You would have to get a new one pressed in.
bairdc3
Honda Civic (2001 - 2005)
Jun 28, 2008 10:29 AM
M3Stylz
Jan 12, 2008 05:47 AM
mrlegoman
Welding / Fabrication
Feb 16, 2007 02:35 PM
LostAndFound
Oct 21, 2006 04:56 PM
Tiwe
Sep 12, 2002 05:59 PM
