Wheel Fitment question
hi, not sure if this is the correct place to post, but does anyone know if the following will fit a 06+ civic si:
18x7 et22 front
18x8 et32 rear
thanks in advance.
18x7 et22 front
18x8 et32 rear
thanks in advance.
going to need to roll your fenders, maybe even pull them a little in the rear for that. definitely will need to run some camber too.
why are you running staggard?
don't run staggered in the rear..if anything run the widest in the front...we do not have rwd. it depends on what suspension you're running on too...if you're not lowered than those would be fine but with just springs i think you'll be okay too but with coils im sure you're gonna have to roll and pull.
