Please Help Tire Problem
Old Feb 15, 2011 | 07:19 PM
SIDreamer's Avatar
Icon2 Please Help Tire Problem
I am having tire/wheel issues. I took my car and had the tire checked at DTC tires today and I was told that Tire is in really good condition. I had a humming sound coming from front right I decided to put tire in rear right, and then the noise went to the rear. I kinda got a clue it was the tire but just to be sure I moved tire to other side rear left and now the noise is coming from there. I am 100% sure it is the wheel/tire and the tire has 75% tread really good condition just got checked today and I did not need a new tire, also wheel has no bends. What could this be?
Old Feb 15, 2011 | 08:12 PM
EJ8mike's Avatar
Default Re: Please Help Tire Problem
U sure there's no uneven wear at all?
Also, is the tire really cheap? Cheap tires will start making road noise early in my experience...
Old Feb 15, 2011 | 08:17 PM
SIDreamer's Avatar
Im not sure if the tires are cheap. All the other tires are good. It's just that one. It is killing my. I just switched it from rear left, to right and again the noise moved. Should i get a new tire? I don't want to get a new tire and the noise stays there, I just never had a problem like this -_-
Old Feb 15, 2011 | 08:21 PM
virgineg6's Avatar
is it the same brand and size as the rest of them? how much tread do your other tires have?
Old Feb 15, 2011 | 08:27 PM
SIDreamer's Avatar
Yea there all the same brand and all all tires have the exact same of tread left.
Old Feb 15, 2011 | 08:29 PM
SIDreamer's Avatar
I know it sounds weird, but thats why I took it to the tire shop and they told me tires are good, I checked my wheel bearings, they are good. The only thing I have bad is my passenger axle which I am changing on saturday.
Old Feb 15, 2011 | 08:42 PM
SIDreamer's Avatar
Tires are Westlake SP06, have not heard of these before. Can nott find a good review to see if any one had wrote that there noisy.
Old Feb 15, 2011 | 09:14 PM
alphalanos's Avatar
I would say get at least two new name brand tires. not ones youve never heard of. Get the alignment checked too.
Old Feb 15, 2011 | 09:16 PM
SIDreamer's Avatar
The reason those tires are on the wheels, I just picked up the wheels this weekend tires where already on wheels. After i get it aligned, and change the axle, if the noise continues I will purchase the tire.
Old Feb 16, 2011 | 06:36 AM
SIDreamer's Avatar
ttt
Old Feb 16, 2011 | 06:57 AM
toyomatt84's Avatar
Sanji
Did the tire shop check the balance on the wheel when they checked it's tread wear?
Has fix-a-flat ever been used on this noisy tire?
How old are the tires?
Old Feb 16, 2011 | 07:02 AM
SIDreamer's Avatar
They where checking for a cupped tire. They said the tread was in ery good shape even all around. Now im not sure if a Fix-A-Flat has ever been used since I just got the wheels/tires. They tires look pretty new they have plenty of tread left.
Old Feb 16, 2011 | 08:53 AM
SIDreamer's Avatar
If anything I will just keep tire until time to replace. It is causing no vibration or nothing just a repetitive humming noise. The tire looks in very amazing shape. Tread is even all around no camber wear. This problem is driving me crazy, but might be something I have to deal with for now.
RanCRX
Feb 24, 2012 10:59 PM
trancedroller
Oct 17, 2007 04:20 PM
mikeunreal2
Mar 1, 2006 02:21 PM
krazyk
Aug 1, 2005 04:39 AM
TypeR1558
Aug 11, 2001 11:58 PM
