What's making my car smoke giant clouds
Old Feb 15, 2011 | 05:24 PM
Built4Battle's Avatar
Default What's making my car smoke giant clouds
My motors a Ls vtec
Car doesn't make any funny noises except a little valve tick
Just changed the headgasket
Did a compression test and came out
#1 155
#2 160
#3 165
#4 170
and I find like oil splash on the bumper and i see oil in my muffler tip as it was spraying oil out
But it only smokes under load like past 3 grand
When I rev it high Rpms it doesn't smoke
Could it be valve stem seals?
Any help will be appreciated
Old Feb 15, 2011 | 05:43 PM
fonkernuckle's Avatar
Default Re: What's making my car smoke giant clouds
What color smoke?
Old Feb 15, 2011 | 07:27 PM
NassTeaNa8-1993's Avatar
time for some rings!
Old Feb 16, 2011 | 01:10 AM
Mostly White but itSmells like mixture of burn out ,oil and coolant
And last time my rings were done everytime I pulled out the spark plug it was like covered in oil but this time spark plugs come out with normal wear
Old Feb 21, 2011 | 05:48 PM
not his 410's Avatar
rings are shot
Old Feb 21, 2011 | 06:04 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
probably didn't break in the rings properly after it was first built.
Old Feb 21, 2011 | 06:05 PM
1998GsRIntegra's Avatar
white=headgasket
with numbers like that the rings are done as well.
Old Feb 21, 2011 | 06:45 PM
fcm's Avatar
fcm
Old Fart
I agree^^^ white smoke = H/G, maybe warped head or deck, would only rule head or deck out if they were done.
The compression is all over the place, [assuming it was properly] either as mentioned, not broken in properly or just worn out.
Valve stem seal(s), [exhaust] leak also a possibility, [oil "splash"], time for a leak down test. 94
Old Feb 21, 2011 | 08:57 PM
el crapitan's Avatar
since you say the smoke goes away at higher rpm, i doubt it's rings.
as mentioned, perform a leakdown
Old Feb 21, 2011 | 09:37 PM
bonesx0x2x4x's Avatar
leak down test for sure listen to where its coming from
Old Feb 22, 2011 | 03:47 AM
Dogginator's Avatar
Daisy... Daisy...
Adjust your valves before redoing a compression or leakdown test.
Old Feb 22, 2011 | 05:01 AM
Community Builder
Compression all over the place? There's less than a 10% variance between all cylinders, which I'm pretty sure is acceptable.
Old Feb 22, 2011 | 05:43 AM
bosoxcelts86's Avatar
Its your piston rings no doubt oil ring on cylinder 1 is probably bad or going bad
Old Apr 4, 2011 | 08:19 PM
just got the block fully rebuilt honed rings bearings etc
still smokes
so im thinking something in the head
and when you rev it even till redline still doesnt smoke
but only when your driving after 3000rpm it smokes
so only thing im left to think is valve stem seals
Old Apr 4, 2011 | 11:18 PM
djkobe's Avatar
as all stated above it could be head gasket, rings, valve seals.. but also try replacing your PCV valve, i broke mine and ran a straight tube from intake manifold to the breather box, drove it to 10 miles to school with a cloud of white smoke following me the whole way. when i got home i pulled off my intake and there was oil all inside of the manifold and throttle body. I replaced it and it hasnt done it since.
just an idea since their only like 2 bucks, but everyone above is much more knowledgeable then i am.
Old Apr 14, 2011 | 03:18 AM
ok so changed the valve stem seals all good now
codyweiss97
Mar 8, 2014 11:04 AM
TheBook
Mar 30, 2013 02:30 PM
shawn69
Oct 1, 2006 09:10 PM
EF'n Sedan
Mar 15, 2006 08:37 AM
Witty
Jul 7, 2003 06:12 AM
