what kind of b series lsd is this
i am not sure what lsd this is the main gear has 66 teeth from what i been reading its itr or ctr but i am not really sure hope someone can help me out i also want to know if its oem
It's OEM. You'll have to shim the diff (it's far easier to do this if you use the enclosed ball bearings instead of the taped roller bearings still on the diff) I can't remember if the GS-R ring gear is the same bolt pattern or not. Aquafina could tell you for sure. I'm going to move this to the transmission/drivetrain section, you should get better responses there.
bocian
Jul 24, 2015 04:20 AM
98GSR-Turbo
Mar 15, 2013 12:48 PM
