Transmission & Drivetrain Gearboxes, Differentials, Clutches
Another Transmission Problem
Old Feb 15, 2011 | 03:22 PM
bmxkills's Avatar
Default Another Transmission Problem
I just recently blew my diff in my 2000 Civic, Poor Man's Type-R swap, GSR tranny. The car runs great, but keep in mind is an OEM rebuilt motor, so there is no major power here. I put in a new OEM open-diff 2 weeks ago from Synchrotech. A Honda Transmission technician and I did the work, everything was done and shimmed correctly, all OEM Honda parts, and Honda MTF. I baby everything, no launches, etc, and I noticed a leak from the outputshaft seal (how the bad diff started before). I tore the intermediate shaft out, and save that the "+" sign on the end of the diff has been sheared off... Again! I can't figure out what is happening! The intermediate shaft is straight, spins straight, but both times the tip of the diff sheared off (as did the rest of the old diff, along with all teeth broken off). However it does seem that the intermediate shaft does not want to bolt up without being pried about 1/4", which would definately stress the diff. Any input? BTW, there should be no reason to suspect bad mounts...
Old Feb 15, 2011 | 05:05 PM
Stine's Avatar
Default Re: Another Transmission Problem
Sounds like youve found your own problem
Old Feb 15, 2011 | 05:16 PM
bmxkills's Avatar
I can't seem to figure out why this is so...
Old Feb 15, 2011 | 05:50 PM
David @ Synchrotech's Avatar
You will need to correct the intermediate shaft problem to prevent another diff failure.
Old Feb 15, 2011 | 06:03 PM
slowcivic2k's Avatar
If the shaft is indeed true you have an external misalignment of the intermediate shaft support bearing. the bearing mount is bent or it is the wrong application.
I've seen a few instances of people shimming the shaft to the block because they could not start the bolts in the block without the use of a prybar. Again also seen many blocks with threads missing for the support bracket.
Cast iron will fatigue and "flake" when the material is distorted, identifying a bent support bracket.
Old Feb 15, 2011 | 06:35 PM
bmxkills's Avatar
It is definately an external alignment problem, I'll try to line up another shaft and see what it does. Synchrotech is the ****!
Old Feb 17, 2011 | 07:24 AM
bmxkills's Avatar
I found the problem, the dude I got the swap off of used the wrong intermediate shaft...
david6969
Mar 10, 2016 10:32 AM
bruce9432
Jul 9, 2012 02:25 AM
Silvertc
Aug 21, 2010 12:08 PM
hydrosmak
Jul 28, 2010 07:58 PM
cranker
Apr 23, 2010 07:53 PM
