b17
ok so i have a b17 with all stock internals and im wondering how the crank and rods would hold up with jdm itr pistons. im looking to up the c/r and with itr pistons it would set me at about 11.04:1
now stock the motor has 160 hp with 117 ft·lbf
and a b16a2 has 160 hp too and 111 ft·lbf
so y do i never here about people swapping b17's or building them?
to my understanding it seems that the rod travel is just a little more but it has the same head as a b16. so what im wondering is truely how good is a b17 compared to a b16? thanks guys i respect your answer
The crank is what gives the b17 the added displacement.
B17a Rod length, 5.208"
B16a Rod length, 5.290"
B16 has a stroke of 77.4, while the B17 has a stroke of 81.4
B17 has a larger deck height; about .07mm taller then the B16. Nearly identical blocks.
We got them in Canada too. I keep hearing production numbers of about 5000. But yes B17A1s were only available in north america. They're esentially a factory B16A stroker. Block and head are both identical to a B16A. Only difference is the rotating assembly. Personally I think they're a good candidate for an NA build. Friend of mine had one for a while and we were going to throw a set of P30 pistons in it but we never did. Car has long since been sold.
b16 put down to the wheel ( 130-150 hp usually stock )
iv seen the same for b17's .. some bolts on u could prolly make 165 170 ,
we tuned a DA with a b17 and some skunk2 cams . . made 168whp.. basing it off that
Crashedcivic
Apr 21, 2009 03:55 AM
QuickDxEk
14
Jan 22, 2008 04:42 PM
Suck my DX
26
Jan 28, 2007 02:47 PM
