EK Civic rear upper control arms, any differences between years
I was wondering if there are any differences in the rear upper control arms for 96-00 civics. The reason I ask is I have a ek coupe that i bought a lil while back and the rear wheels have some very very nasty negative camber. The camber is identical on each side.... I looked over everything and nothing appears bent. the wheel bearings are also good. I got to looking closer and the both upper arms have yellow writing on them (the kind of markings junk yards usually put on parts). If anyone knows the answer please let me know. Im gonna check honda part numbers online to see if there is any differences between the EK years.
I looked at honda parts catalog online, and it appears both the rear upper and lower arms are the same part number from 96-00 ek. I guess ill have to look closer and see what the problem is. As I said erlier the negative camber is equal on both sides in the rear. Also forgot to mention this is stock ride height. Any ideas
swizz977
10
May 18, 2012 05:27 AM
