98 civic hx loud shuddering/vibration
Old Feb 15, 2011 | 11:52 AM
houstoncivichx's Avatar
Default 98 civic hx loud shuddering/vibration
I'm getting this loud shuddering/ vibration from the front of my car when I come to a stop especially in drive thru lines, it only lasts for a few seconds and usually only happens in the morning on my way to work. I'm stumped and need some help.
Old Feb 15, 2011 | 11:56 AM
Former User's Avatar
Default Re: 98 civic hx loud shuddering/vibration
Only when braking?
Old Feb 15, 2011 | 12:12 PM
Not while I am braking but when I'm at a complete stop, but the brake pedal and clutch pedal are pushed.
Old Feb 15, 2011 | 12:15 PM
Sounds like a low idle problem. Any CEL codes?
Old Feb 15, 2011 | 12:20 PM
No cel codes
Old Feb 15, 2011 | 12:21 PM
Stock HX?
Does the CEL work? How did you check for codes?
Any problems while driving?
Old Feb 15, 2011 | 12:27 PM
Yes it is stock. Yes the light works when I start my car. I have a scanner at home. No other problems while driving only this intermittently.
Old Feb 15, 2011 | 12:30 PM
The noise kind of sounds like if you are putting it in gear and letting out the clutch but not giving it enough gas, the noise when it is trying to stall out.
Old Feb 15, 2011 | 12:35 PM
Have you tried cleaning the IACV and adjusting the idle speed?
Manual transmission, right?
Old Feb 15, 2011 | 12:38 PM
No but I will when I get home from work.
Old Feb 15, 2011 | 12:40 PM
It might also be worth checking whether the EGR valve or chamber is clogged with carbon.
christopherLom
13
Sep 29, 2011 10:53 AM
smd6942
Aug 10, 2010 06:19 PM
dothedrew28
Dec 30, 2008 09:31 PM
SauN
Honda Civic (2001 - 2005)
Jun 22, 2008 01:33 PM
Gant
Sep 15, 2004 10:13 PM
