No speedo / Water temp gauges
Old Feb 15, 2011 | 11:44 AM
mackinit's Avatar
Default No speedo / Water temp gauges
Hey everyone,
Just wanted to start by introducing myself to the forums. I'm Cody, and I've got a '97 b20b integra with the stock ls trans. I'm new to the honda scene, my experience has been in audi / vw and nissans.
I tried searching briefly, but couldn't find an exact answer. My speedo and coolant temp gauges are not functioning at all. I just got the car, the prev. owner said they both work intermittently, but i've only seen the temp gauge move a few times. Speedo has been stuck on 0 the whole time.
Obv. because I have no speedo, I also have no Odo.
I figured it was probably just the sensors, but I took a speed sensor out of a junkyard teg, and it didnt do anything. I may have not got the whole thing though. I think it was just the clip, it didnt come out of the whole trans. only 2 10mm bolts.
Any help would be appreciated!
Thanks,
Cody
Old Feb 15, 2011 | 11:50 AM
Mindgamez's Avatar
Default Re: No speedo / Water temp gauges
The Sensor does come out of the trans. It should just lift right out, try using a pry bar. As for the coolant, check to see if he messed up wiring anything or if anything is un-clipped.
Old Feb 15, 2011 | 11:58 AM
mackinit's Avatar
Haha yeah, that's what I figured.. I didn't bring a prybar to the junkyard, and my flathead wasn't enough to pop it out.
Old Feb 16, 2011 | 03:54 PM
mackinit's Avatar
wires seem fine.. any other ideas?
Hughie1987
Mar 9, 2013 10:53 AM
skidmarkroyalty
Jan 11, 2009 03:04 PM
ferio 95
Jan 13, 2005 05:15 AM
Casey
Mar 18, 2004 10:22 AM
ten_30
Oct 2, 2002 11:08 AM
