Transmission wont shift into second
My transmission wont go into second gear its an auto.
any ideas on what it could be? I just replaced it the tranny only has 60,000 on it. fluid is good and all other gears work.
any help would be great thanks!
If its a Chevy Blazer replace the transmission, quite common on those.
Check the TCM, make sure the kickdown cable is adjusted properly, make sure the shift/lockup solenoids are functioning properly. If all that checks out replace the transmission.
No, technically the Integra doesn't have a PCM, it's got an ECU for the engine and then a TCU/TCM to control the transmission, it's directly below the ECU IIRC.
The testing procedure is in the service manual (which I don't have)
Could be.
Could be.
Nate.Hamm
Jan 12, 2021 01:45 PM
thecorey
12
May 18, 2005 04:23 PM
