Determining ZC generation?
Old Feb 14, 2011 | 05:51 PM
hexrx's Avatar
Icon3 Determining ZC generation?
Hey I have a ZC in my '90 civic SI and the time has come to replace the valve cover gasket and I need a new wiring harness as the guy who installed it was a failure at life and caused me more grief than necessary.
Can anyone please let me know what generation ZC this is?
ZC 2213175
Thank you guys
Old Feb 15, 2011 | 03:12 AM
~sp33~'s Avatar
EFB055
Default Re: Determining ZC generation?
Black top OBD 0 87-91. Gen 2.
Old Feb 15, 2011 | 07:48 AM
Young Guna267's Avatar
correct me if i'm wrong, but isn't there a date stamp on the head near the handle of the dipstick?
Old Feb 15, 2011 | 11:55 AM
hexrx's Avatar
Ill check the date now, '88 on the head by the dipstick..
Thank you guys very much!
Old Feb 15, 2011 | 12:08 PM
jessedm's Avatar
nice zc bro makes me sad to have sold mine
Old Feb 15, 2011 | 12:14 PM
hexrx's Avatar
The guy I bought the car from failed at wiring it and I need to basically rewire the entire engine.. Anyone know where I can get a kit? I have no experience wiring so I am taking it to a shop..
Does anyone know what OBD the civic is? (1990 Civic SI) it is "OBD 0 MPFI" right?
and the ZC is OBD O MPFI as well. So where do I go from here? Sorry trying to learn fast heh
Old Feb 15, 2011 | 12:27 PM
jlicrx's Avatar
what is wrong with the wiring?
Old Feb 15, 2011 | 12:33 PM
hexrx's Avatar
>..< The shop I took it to said that it is the wiring.. plus when you look at it, it is the shittiest wiring job I have ever seen.
But the problems are as follows, and everyone is saying its electrical
"I looked back at the ecu, and it is throwing a few codes... (7 blinks - TPS) (8 blinks - TDC) (14 blinks - IACV)
Could this cause the car to bog out(It cuts out and will only rev to 2000 rpms untill I cut the power then it is fine, even whilst driving.) when and only when I floor it?
The car will randomly not start, something with the clutch, because if I slam it hard enough it will start sometimes
The car is running extremely rich.
There are no check engine lights."
Old Feb 15, 2011 | 12:39 PM
hexrx's Avatar
also a few of the wires connecting to the Dizzy are frayed and 3 of them I had to electrical tape back together, heh.
Old Feb 15, 2011 | 12:44 PM
jlicrx's Avatar
don't know how they could screw it up - wiring for the DOHC ZC swap into the Si is about as simple as you can get - the only change needed is at the distributor - remove the round 7-wire connector from the Si engine harness and replace it with a rectangular 5-wire connector from any 88-91 DPFI CRX/Civic or 88-89 Integra or OEM DOHC ZC engine harness - just match the 5 wire colors on each side of the connection - obviously, if you are repalcing a 7-wire connector with a 5-wire connector, you will have 2 wires left over on the engine harness - they are blue with a green stripe and blue with a yellow stripe - add a short piece of wire to each of thes and extend them to the Cylinder sensor on the end of the exhaust camshaft, again matching the wire colors - everything else on the Si harness plugs right into the ZC sensors - you will have one connector left over which went to the Fast Idle Control Valve on the back of the Si intake manifold - just leave it not connected as the ZC doesn't have a FICV
your best bet is to try and find an uncut 89-91 CRX/Civic Si engine harness and start over - not an easy thing to find these days
most of your problems are due to the codes - the clutch switch could just need adjusting
Old Feb 15, 2011 | 12:50 PM
hexrx's Avatar
Thank you so much for the reply!
Any ideas on the fact that I cannot floor it because it will bog down and wont come back up untill I restart?
Old Feb 15, 2011 | 01:03 PM
jlicrx's Avatar
probably the TPS (code 7) or it could be the TDC (code 8) causing the ECU to go into limp mode - only way to cure it is get rid of the codes - the code 14 may be because it has the wrong connector plugged into the EACV or could be low coolant level - the connector for the EACV is 2-wire with black with yellow stripe and blue with yellow stripe wires - the connector for the FICV (which you don't have) is just like the connector for the EACV except for wire colors - it also has black with yellow stripe and the other one is just solid blue (no yellow stripe) - easy to get them swapped
Old Feb 15, 2011 | 01:24 PM
hexrx's Avatar
On the back of the Programed fuel injector thing there is a black peice I think its on the IACV but this peice plastic that has a cable running to it, I just plugged the cable in.. I wonder if it fell out and caused all this?!
Old Feb 15, 2011 | 08:14 PM
hexrx's Avatar
ROFL!
Fixxed it
Old Feb 15, 2011 | 09:29 PM
~sp33~'s Avatar
EFB055
, lol. Congrats on the easy fix.
Old Feb 15, 2011 | 09:46 PM
hexrx's Avatar
Time to throw back in the Integra ECU, was running the stock one trying to lean it out but no smoke, not much soot, and I can floor it :D
Old Feb 18, 2011 | 07:49 AM
Dual-500's Avatar
Suggest you pick up some heat shrink tubing and clean up the wiring mess - or you'll be back to this square again......
Old Feb 18, 2011 | 08:32 AM
KINGVEM^^ED6's Avatar
x2
turnsignalandy
Apr 17, 2006 10:46 PM
The Destroyer
11
Dec 30, 2005 02:22 PM
RACEPAK
May 18, 2005 11:03 PM
messeduprex
Apr 2, 2004 01:47 PM
