ek w/ b16 smoking
Old Feb 14, 2011 | 01:14 PM
bradabu's Avatar
Default ek w/ b16 smoking
i have a b16 that it constantly blowing out white smoke, and when i accererate it comes out alot. i mean ALOT! and i check my oil and its low so i fill it up and after driving its goes down again...i ran open headers for a day after the swap and i had oil spill coming out the headers. what can it be? rings? valve stem seals? head gasket? but my coolant is still good and full and car doesnt over heat
Old Feb 14, 2011 | 01:33 PM
EJ8_Man's Avatar
Default Re: ek w/ b16 smoking
Sounds like your rings are gone. Does the smoke have a bluish tint to it? You can perform a leak down test to confirm. You can also look at your spark plugs. Is there heavy carbon deposits on them? That's typically burnt oil. I just went through this with my B18C. Time for a rebuild!
Old Feb 14, 2011 | 02:25 PM
bradabu's Avatar
i believe its just white
Old Feb 14, 2011 | 02:42 PM
EJ8_Man's Avatar
Does your oil turn black really fast? What do your plugs look like? Any oil in the coolant? Any coolant in the oil? Could be your valve stem seals, but I doubt it. Sounds like rings to me
Old Feb 14, 2011 | 03:21 PM
zeroek's Avatar
Valve guides or Rings. Compression test and leakdown test time.
Old Feb 14, 2011 | 05:16 PM
Hondatherdm's Avatar
white = coolant, seals, ring = blue smoke
Old Feb 14, 2011 | 05:33 PM
SolScifen's Avatar
If hes got oil leaking and white smoke that that sounds like a bad head gasket
Old Feb 14, 2011 | 07:31 PM
YoungMula[Ej1]'s Avatar
Valve guides or Rings. Compression test and leakdown test.
Old Feb 14, 2011 | 07:41 PM
bradabu's Avatar
i did a compression test and got this
cyl 1: 130psi
cyl 2: 160psi
cyl 3: 170psi
cyl 4: 170psi
and i have no oil in coolant and no coolant in oil...
Old Feb 14, 2011 | 07:42 PM
bradabu's Avatar
it has a strong smell and stinks. i burn like 1qt of oil in like a day
codyweiss97
Mar 8, 2014 11:04 AM
Built4Battle
Apr 14, 2011 03:18 AM
blackmfoggie
Sep 7, 2007 07:34 PM
EFHATCH88
Dec 29, 2006 01:05 AM
Witty
Jul 7, 2003 06:12 AM
