Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
***Limited Edition APEXi Clear Turbo Timers***
Old Feb 14, 2011 | 01:00 PM
UpNextCarParts's Avatar
Default ***Limited Edition APEXi Clear Turbo Timers***
Check out this Limited Edition, clear turbo timer offered by APEXi Part #: 405-A931.
This is a limited production item and will not be available again once stock is gone.
Get yours today for $108.99, FREE Ground Shipping! (Continental U.S. Only)
Don't forget about our current AEM UEGO Wideband Special.
Plug and Play Turbo Timer harnesses available starting at $13.99
Description:
A'PEXi Full Auto Turbo Timer is a compact pen shaped turbo timer that makes mounting this turbo timer a snap. This compact design allows for a clean and stylish installation virtually anywhere inside the cabin. This turbo timer is equipped with a multi angle joystick button that allows users easy navigation through many of its feature. This turbo is equipped with an auto timer function, manual time function, Air/Fuel ratio, O2 sensor voltage, and battery voltage. This tiny gadget has many features for its size. Turbo timers allows vehicles to idle for a preset amount of time after the ignition key is removed to prevent hot oil from clogging or chocking in lines, especially after hard driving. Adequate cool down is essential for a long lasting, healthy motor.
Old Feb 15, 2011 | 08:44 AM
Default Re: ***Limited Edition APEXi Clear Turbo Timers***
Bump
Old Feb 23, 2011 | 12:35 PM
Bump
1QwIkEf
Feb 8, 2009 05:00 PM
mr abstract
Sep 21, 2006 04:57 PM
.Radical_Edward.
Oct 13, 2005 02:59 PM
