V-Tech motor will not work
I have a 1992 Honda Accord. I changed the transmission from automatic to manual. The motor is a 1998 VTEC. Now the VTEC motor will not work. Can someone please tell me why this happened? Thank You.
What does this mean, the car won't crank, it cranks but shuts down, how would I know how this happened, aside from the obvious fact that you might be the cause.
Btw, you are about to catch hell for that H at the end of VTEC...
needs spacers in the rear. front looks pretty good though.
not a fan of that lip or those wheels, but it looks pretty good on your car!
the v-tech is your problem take out the phone out of motor and it should run.
did you connect the 2 wires by the shifter to allow car to start. get a manual ecu and wired vtec?
Are you running the F23A1 or A4? Do you have the correct ECU? Since your car was OBDI did you have it wired to OBDII?
Off topic: Where did the flux Capacitor come from again? Which Movie? LOL.
Oh boy VTECH. How can you misspelled something that is written on your Valve Cover.
