crap, new h22 swap done, was running, now wont start
Old Feb 14, 2011 | 08:36 AM
Brownjd's Avatar
Default crap, new h22 swap done, was running, now wont start
it was running the last 2 days for short periods of time while i was finishing everything up, now im done with everything and it was running and then shut off and wont start now. i have fuel, but no spark. checked all grounds again, what else to check?
Old Feb 14, 2011 | 08:58 AM
accordmatt's Avatar
Default Re: crap, new h22 swap done, was running, now wont start
dizzy connections,fuses,cap, coil rotor if ur not getting spark thats the issue. pull plugs and check them also
Old Feb 14, 2011 | 09:04 AM
Brownjd's Avatar
ok ive got power to the coil, no spark at the plugs. could it be the igniter? how do i check that?
Old Feb 14, 2011 | 09:26 AM
accordmatt's Avatar
if u have power to coil ur ignitor should be ok but if not google it and they explain how to test. not positive but i think u need to have a volt meter and test with key in on position.
Old Feb 14, 2011 | 10:04 AM
Brownjd's Avatar
ok, everything looks good with the coil and igniter, that probly means my distributor just took a **** on me, right?
Old Feb 14, 2011 | 10:18 AM
accordmatt's Avatar
possible l would double check wiring. and cap and rotor good luck man l just finished mine and thinking l might have to pull it back out. piston ring might be fried
Old Feb 14, 2011 | 10:43 AM
Brownjd's Avatar
hope not, that would suck! well im thinkin its gotta be the dizzy, since all the grounds are good and brand new cap and rotor and it was running fine this morning then just died.
Old Feb 15, 2011 | 06:11 AM
Brownjd's Avatar
update...put a new distributor on this morning and all is fine. all i have to do is change the tensioner and bleed the clutch and we should be good!
Old Feb 15, 2011 | 08:11 AM
GhostAccord's Avatar
It was probably just the ignitor, it states in the troubleshooting that if everything else in the ignition passes testing, including the ignitor, too replace the ignitor. I have done this on many occasions and it has worked.
Keep your old distributor as a spare, it is more than likely still good. Just replace the ignitor. Unless you had to take it in for a core.
the soL that could
15
Aug 27, 2011 06:44 PM
dan89crxsi
Feb 10, 2007 02:44 PM
rdssk8rcs1
Jun 5, 2006 04:13 PM
oMek
Jan 22, 2005 07:17 PM
liquid51
Jul 22, 2003 06:47 PM
