FS/FT Z6 motor and trans for wheels or ?
Old Feb 13, 2011 | 06:05 PM
MisterMonkey26's Avatar
Default FS/FT Z6 motor and trans for wheels or ?
Considering trading my z6 motor and trans. I bought the motor from a family member and was pulled out of a 93 si. The motor had around 93-94k on it so the head was removed and was going to be rebuilt and dropped into MY si then was gonna boost it but decided that with work and everything I have going on I should just leave alone (have a rebuilt d15b7 in it ). The motor didn't smoke before head was removed so I have no reason to think it'll smoke now.The timing belt cover is missing and the bolts for the water pump are also missing but im sure Ill be able to find them in my bucket of bolts ( recently went through a move and had to pil everything up Has intake manifold and TB ( not pictured but are here )but no dizzy,or injectors. The trans didn't grind or have troubles either but has been outside Under a carport the motor however has been in a garage since pulled and taken apart ). Should be still in perfect order just felt id mention it. No shift linkage or axles. Would make a good turbo project or for someone who wants to have close to everything for a vtec swap. Im wanting to trade for some 4x100 15/16 rotas, drags, xxrs. Would like for them to be in decent shape but tires are not needed Also have the vtec wiring harness. I figured like 450 for everything. Feel free to shoot me a message or a text 931-607-7181. Hopefully soon I will have an engine stand to snap some pictures of the bottom without the oil pan on. Until then I hope these help
Old Feb 15, 2011 | 02:26 PM
Default Re: FS/FT Z6 motor and trans for wheels or ?
bumparoo
semse2
24
Jul 22, 2020 05:41 AM
zeusdavis
Mar 22, 2011 10:16 AM
2fastss
Jul 9, 2009 03:19 PM
koulaid
Oct 27, 2008 09:52 AM
ED9 Y-49
Sep 9, 2006 12:04 PM
