Suspension & Brakes Theory, alignment, spring rates....
Air Bubbles
Old Feb 13, 2011 | 05:22 PM
andyz's Avatar
Default Air Bubbles
No end to the air bubbles. I can't get rid of all the air bubbles. Where the hell are the air bubbles coming from. Can't be that much air in the whole F*** system!
Is it the S**** reman caliper I bought? Or maybe the S***** bleed screw on the S**** reman caliper?
A different bleed screw? The master cylinder? The prop valve? A Fitting?
HELP need brakes need to drive
Old Feb 14, 2011 | 06:47 PM
roastbeefrichie's Avatar
Default Re: Air Bubbles
Originally Posted by BrakeExpert
after caliper installation, here is the CORRECT bleeding sequence:
Bleed the brakes Right Rear, Left Front, Left Rear, Right Front. You do not go farthest to closest with Hondas.
Always bench bleed the Master cylinder when replacing the master cylinder, ABS unit, or proportioning valve.
regal1975
Mar 28, 2014 06:02 PM
