help please: cold starting issues
Old Feb 13, 2011 | 02:51 PM
NYCE's Avatar
Default help please: cold starting issues
I have a 91 integra ls that is giving me problems starting when its cold. i replaced the fuel pump but it still does not start. it will start with starter fluid and once it gets started and warms up it'll be fine. thanks any help is appreciated
Old Feb 13, 2011 | 02:54 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: help please: cold starting issues
Will it start if the accelerator is slightly depressed?
Old Feb 13, 2011 | 03:02 PM
NYCE's Avatar
It only starts with starter fluid when its cold but once i spray and hit accelerator itll start.. i usually have to spray starter fluid about 2-3 times
Old Feb 13, 2011 | 03:03 PM
el crapitan's Avatar
does it crank? slow crank? no crank?
Old Feb 13, 2011 | 04:33 PM
NYCE's Avatar
it cranks but does not turnover with out starter fluid..
Old Feb 13, 2011 | 04:45 PM
check spark cold. then fuel. although the fact that it starts with starter fluid does lean towards a fuel related issue. maybe not priming. crack the fuel line, and see if it primes
and you're hearing the main relay click 3 times?
Old Feb 14, 2011 | 05:15 AM
StayinOnlyOneYr's Avatar
by a heater for the motor... I heard you can get them off ebay
CiViC I2aCeI2
Mar 12, 2006 03:53 PM
Joebroni
Sep 26, 2005 10:43 PM
DOHC_C-REX
Sep 7, 2004 09:55 PM
2muchPSI
Dec 22, 2003 06:58 PM
92civeg
Sep 23, 2003 08:23 PM
