1996 itr 4x114.3 - What does the 23T caliper bracket come off of?
I know this has been covered many of times, but I have read a lot, used the search button and even google. I can't find a solid answer. I bought the conversion from a local shop, it came with 92 prelude calipers (not sure which prelude), and no rotors. the calipers are stamped with 17CL14VN (Integra calipers?) and the brackets are 25K on the right side and 25L on the left side, I have read stuff about 23T and 25T work blah blah blah, I want a firm answer. I don't mind having to upgrade to the 11.1" rotor (I would actually like to, I know I will need the bigger BB and MC or prop valve, that is fine) I have the rear everything, just need to know about the fronts. I want this conversion on now. :D Thanks for the help in advance, Robert
Are you asking what you need to upgrade the fronts to 11.1"?
https://honda-tech.com/forums/suspension-brakes-54/4x114-3-front-brake-replacement-info-2642918/
sumyungguy
33
Mar 30, 2006 06:59 PM
integra-modder
Aug 16, 2003 01:17 PM
