Dizzy/ECU compatibility
Old Feb 12, 2011 | 02:03 AM
hammergunner's Avatar
Default Dizzy/ECU compatibility
well i have an OBD2a b20 that im going to install in to a 89 hatch and ive already done the MPFI conversion and bought a obd0 to 2a dizzy jumper(10 bucks so just got it)
and wanted to know if any other ecus can be used with obd2 besides odb2 ones.
i know OBD0 ecus are out of the question since they have the 16 tooth crank count and the 0bd1 have 24 tooth
but will an obd1 ecu worth with an obd2 dizzy, And i want to use obd2 parts since they are newer.
Old Feb 12, 2011 | 04:03 AM
ef92b's Avatar
Default Re: Dizzy/ECU compatibility
Yes, you can use an OBD2 dizzy with an OBD1 ECU. just make sure you do the proper harness conversion.
Old Feb 13, 2011 | 12:26 AM
cool thanks for the heads up, Ive already got a p28 catchin dust, so ill just chip that and get a obd0 to 1 ecu jumper
Joeski99Si
Sep 4, 2008 10:18 AM
Spracer03
Jan 22, 2008 08:16 AM
dawrenn
Sep 2, 2005 02:42 PM
C_I_V_I_C
Nov 5, 2003 05:26 PM
