Piston-to-Wall Clearance/Piston size question
Old Feb 11, 2011 | 08:26 PM
madking411's Avatar
Default Piston-to-Wall Clearance/Piston size question
I have a piston/rod from an old LS block and I recently got a micrometer and have been practicing measuring internals of an engine...anyways... My question is, that I looked in the repair manual and it states that the piston diameter is supposed to be in the range of 3.1882" up to 3.1886". I measured this piston out to be 3.1776". That is too small, and outside of the serviceable range. Is it an actual possibility that the piston rubbed up against the walls so much that it essentially ''shrunk'' the piston?
Old Feb 12, 2011 | 08:02 PM
QUICK8CIVIC's Avatar
Default Re: Piston-to-Wall Clearance/Piston size question
You should measure piston diameter on the skirts, approx 0.5in up.
cjmurillo
Dec 25, 2008 08:40 PM
TURBODC4TEG
Jul 19, 2006 06:21 AM
johnSiR
Sep 13, 2002 06:56 AM
2000si
Dec 10, 2001 04:16 PM
