piston question?
Old Sep 13, 2002 | 06:25 AM
johnSiR's Avatar
Default piston question?
I am planning to build my internals, and my tuner from Manila, Philippines just emailed me and told me to get:
Pistons: JE 81.00mm (no more 81.50) remember flat head; only with the valve's pokets
I want to ask the boost gurus out there............and for opinions:
1.) What is the advantage or disadvantage of getting 81mm instead of 81.5mm?
2.) what is the meaning of having a "valve's pocket" in a piston? advantages/disadvantages in a piston of a boosted car?
3.) in regards to strengthen the cylinder........is putting ductile sleeves the solution or is something else?
thanks!
Old Sep 13, 2002 | 06:32 AM
X2BOARD's Avatar
Default Re: piston question? (johnSiR)
The 81 and 81.5 mm measurements are bore size of the piston/cylinder wall. The larger the size, the more displacement you get... I think 81.5 is close to a 1.9 total displacement on a 1.8L motor.
The pockets you refer to are prolly the valve reliefs, menat to give extra space for clearance on the top of the piston. They look like someone took a large coin and pushed in the 4 corners on the piston.
Higher compression pistons are typcially domed and have deeper valve reliefs, but for lower compression turbo pistons you want to go with a flat or dished piston (which also have shallow valve reliefs). A dished piston, like Je's dished turbo piston is designed to promote proper mixture and aid in flame peopagation under boost.
X2
Old Sep 13, 2002 | 06:36 AM
ekb18c's Avatar
Flat top pistons which is around 10:1 compression.
Old Sep 13, 2002 | 06:56 AM
johnSiR's Avatar
Default Re: piston question? (ekb18c)
so.....81.00mm remember flat head; only with the valve's pokets (recommended by my tuner) ............is the best piston to boost my turbocharged b16?
what is his logic for having valve pockets on a flat headed piston for increasing the boost?
also, to build a bottom end................do I need to get a new set of cylinder? or getting "sleeves" will make my bottom end stronger? are these (cylinder and sleeves) not related?
lude98SH
Dec 20, 2007 05:05 AM
pootie.teng
Dec 11, 2006 01:55 PM
x2gold
May 16, 2006 05:10 PM
gregsr
Aug 17, 2003 01:49 PM
B00STeD
Sep 24, 2002 01:36 PM
