Ej8 resistor box wiring questions
Old Feb 11, 2011 | 02:22 PM
CPreston's Avatar
Default Ej8 resistor box wiring questions
Ok so I'm pretty sure I've got this correct but I just want to make sure before I go cutting my wires.
I take the black/yellow wires from the injectors and I cut them, wire each of the injector side wires to a individual yellow/black wire on the resistor box, then take the 4 other ends of the wires I cut and twist them
Together and wire them to the red wire on the resistor box?
Also if that is correct, say I want to go back to stock, the only way to do that would be to do the same thing in reverse and just wire them all back to stock?
Old Feb 11, 2011 | 02:38 PM
94EG8's Avatar
Seagull Management
Default Re: Ej8 resistor box wiring questions
If you think you might want to go back to stock i'd suggest you do this -> https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/complete-diy-plug-play-obd2-civic-resistor-box-write-up-ej6-ej7-ej8-em1-eg1-eg2-eh6-2073540/
komat
Aug 25, 2007 04:38 PM
7808
Dec 13, 2006 08:52 AM
vladd
Aug 4, 2006 04:28 PM
Project92Hatch
Feb 16, 2004 03:46 PM
freeplay
Oct 10, 2002 12:16 AM
