jdm itr header
Old Sep 25, 2002 | 10:49 AM
S2GSR's Avatar
Default jdm itr header
i was wondering if i would have trouble passing emissions the the jdm itr header. Plus, what would make my car not pass emissions.
Old Sep 25, 2002 | 11:03 AM
92TypeR's Avatar
FSAE
Default Re: jdm itr header (S2GSR)
The DC version is CARB and DOT approved. I could only assume that it follows the same lines as the OEM JDM ITR 4-1. But with the heat shields on, I wouldn't see any problems with an inspection. Otherwise it shouldn't adversly effect you passing emissions.
No cat, crappy computer, and CEL's are what I see causing most failures in Hondas.
Old Sep 25, 2002 | 12:21 PM
Hooch'n's Avatar
Default Re: jdm itr header (92TypeR)
Depends on State..............South Carolina no restrictions but in North Carolina you have to register your car and have emissions done.
Old Sep 25, 2002 | 12:32 PM
clemsonsi's Avatar
Default Re: jdm itr header (Hooch at 8400-RPM)
trust me...living in South Carolina only has a few benefits
the lack of emissions testing here has kept me in the palmetto state
Old Sep 25, 2002 | 12:50 PM
Hooch'n's Avatar
Default Re: jdm itr header (clemsonsi)
I have no probs with the Carolinas.......love charlotte.
Old Sep 25, 2002 | 01:04 PM
SurferX's Avatar
The DC JDM is not CARB approved.
Old Sep 25, 2002 | 03:15 PM
machgo5go's Avatar
While on this subject, what is now avaliable in the market that i can bolt everything together without cutting, welding and screw around?? JDM R header + Shield + What BRACKET? + What CAT with right flange and O2 sensor hold ? to stock B- Pipe?
I am getting too old to cut and splice, just want to bolt it together.
[Modified by machgo5go, 7:16 PM 9/25/2002]
Old Sep 25, 2002 | 03:32 PM
Obee1.8's Avatar
Default Re: jdm itr header (machgo5go)
JDM 4-1 with carsound hi-flow cat will bolt right up to stock B pipe. Don't forget you need the JDM donought gasket to use with the JDM header. Inlinefour.com,is one of many places you can get this item. Spoon N1 muffler section will also bolt up to stock B pipe.
Old Sep 25, 2002 | 03:45 PM
98itR484's Avatar
Default Re: jdm itr header (SurferX)
ee-gsr
Jun 22, 2013 12:08 PM
si90rex
Welding / Fabrication
Feb 21, 2007 05:41 AM
jlsmi2
Jun 21, 2004 04:27 PM
kepani
Nov 3, 2001 04:57 PM
