Honda CR-V & Element 2WD & 4WD Element & CR-V
98 crv
Old Feb 11, 2011 | 11:54 AM
decode33's Avatar
Default 98 crv
Just buyed GM motors X66A carb cleaner and will clean my dirty IAC valve. I am in saudi arabia and have noticed there are no heater/coolant lines on my IAC valve (doesnt snow here). Will do this next week....
Also I have noticed that I loose water (dont put coolant here in the desert) in the coolant bottle in the 98 crv. I loose half a bottle every week or two. There are no leaks at all and car has no problem. Is this normal.
Old Feb 12, 2011 | 01:00 PM
ALPHA MOVEMENT's Avatar
Default Re: 98 crv
Hi,
It's NOT normal here in Canada. But we do use engine coolant all the time in our coolant systems. Are you sure you don't put coolant in the desert? I don't think water will be sufficient regardless of the temperatures.
Maybe I am wrong?
Old Feb 12, 2011 | 01:05 PM
Default Re: 98 crv
I've read that soldiers in the desert use 70% engine coolant and 30% distilled water for desert purposes. Also, you should check your radiator cap. Because you are using only water, the water might have evaporated before you can notice it leaking on the floor, etc.
Good luck!
Old Feb 14, 2011 | 07:32 AM
decode33's Avatar
Default Re: 98 crv
I kind of figured it out to my coolant loss problem. There are no white smoke in the morning, checked it today. But I have noticed lot of rust and some deposit (like a water reaction or somthing) in where the coolant hose connects to the engine. All the other coolant connections are fine, no rusty deposits. The radiator cap is new. So probably when I am driving, the coolant evaporates from there.
zpower
Nov 21, 2012 04:15 PM
dth0ng69
18
Jul 19, 2009 09:12 AM
vinceiscoo
12
Sep 5, 2008 11:02 AM
SpoonIntegra808
Oct 21, 2004 05:04 AM
LillDragun
Oct 25, 2002 07:44 PM
