K20 CEL says VTCE Failure?!
Old Feb 11, 2011 | 09:36 AM
macDelli's Avatar
Icon6 K20 CEL says VTCE Failure?!
I'm new to the k series game and was wondering what this might be indicating?
Is it a solenoid problem, oil pressure?! Any help would be appreciated
TIA
Old Feb 11, 2011 | 10:08 AM
nahonda04's Avatar
Surje.motorsports
Default Re: K20 CEL says VTCE Failure?!
what is the CEL number?
Old Feb 11, 2011 | 10:36 AM
DaveSi677's Avatar
Cell number
Old Feb 11, 2011 | 10:59 AM
macDelli's Avatar
p1259
Old Feb 11, 2011 | 11:08 AM
macDelli's Avatar
I'm sorry this would be VTEC malfunction... so solenoid i take it?!
Old Feb 11, 2011 | 12:52 PM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
ive never had a VTCE failure?
Old Feb 11, 2011 | 12:58 PM
DaveSi677's Avatar
Could be solenoid... I'll check when I get home!
Old Feb 11, 2011 | 01:10 PM
macDelli's Avatar
That's what i'm guessing. I'll pull it off to try leaning it and see it that at least helps. Any other imput would be appreciated though...
Old Feb 11, 2011 | 01:58 PM
nahonda04's Avatar
Surje.motorsports
vtec solenoid, pressure switch or check to see if solenoid is plugged in lol
Old Feb 11, 2011 | 02:24 PM
DaveSi677's Avatar
could running low oil trigger this one??? I'm not 100% sure... just idea till I get home!
Old Feb 11, 2011 | 07:46 PM
Targa250R's Avatar
be professional
Check the oil level. Low oil is the number one cause of P1259.
What engine is this? K20A2? K20A3?
Old Feb 12, 2011 | 09:16 AM
macDelli's Avatar
It's the k20a2. Oil level is fine I regularly check and change it. I popped the solenoid off and found it was pretty dirty so I cleaned it. No change...
Old Feb 12, 2011 | 10:13 AM
Targa250R's Avatar
be professional
Is VTEC engaging?
Did you remove just the solenoid, or did you remove the entire VTEC spool valve and clean the gasket filter screen?
Old Feb 12, 2011 | 11:28 AM
hawaiiancb74's Avatar
remember a dirty vtc can cause this too. sensor middle of the timing cover just under the valve cover
94wip
12
Jun 20, 2024 07:23 PM
hondahead'
13
Aug 3, 2009 07:11 AM
high_octane
Jun 16, 2009 01:55 PM
speedhatch
Jan 24, 2006 01:50 PM
BeeResp0nsible
Nov 29, 2002 05:43 AM
