97 ek runs warm for unknown reason need help
Old Feb 10, 2011 | 09:25 PM
bakomack's Avatar
Default 97 ek runs warm for unknown reason need help
97 ek auto with y7 all stock.
145k miles
run coolant, brand new cap and thermostat
water pump doesnt leak, car has no leaks at all.
no oil in the radiator
no water in the oil
I have the fan switch jumped so fan runs all the time car is on. but car eats water and has to be topped off every 2-3 days
it seems like when ever I floor it then get off it the temp rises a lil. then when I get on the gas about 1/8 throttle you watch the needle rise to about 3/4 but if you let off the gas or turn on the heater temp drops to normal.
do I have a blown head gasket thats just leaking to the exhaust or something or am i over looking something. need helpl please, dont have the money to get a gasket and have the head surfaced.
other than that motor runs great peppy as ****. just want this over heating prob fixed for my girl to drive my 3 month old around thanks guys
Old Feb 11, 2011 | 12:35 PM
bakomack's Avatar
Default Re: 97 ek runs warm for unknown reason need help
wtf, no replies at all?
anyways since it was running warm and kinda had a mind of its own last night we parked it, this morning checked the coolant and it was full.
no idea why this thing even gets hot in the first place. anyone have a suggestion?
Old Feb 11, 2011 | 12:47 PM
delsizzle1's Avatar
just because your water pupm isnt leakin doesnt mean its workin.... pop open the cap to the radiator when its cold start it up and let it get warm, and try see if u can see the coolant travel if it isnt more than likely it isnt spining
Old Feb 11, 2011 | 01:18 PM
hmoobhero's Avatar
has the water pump been replaced? with 145k miles water pump and timing belt should have been replaced.
Old Feb 11, 2011 | 03:40 PM
NastyHabitzCRX's Avatar
are you sure the sending unit isn't going bad? also if you have a blown headgasket look at the plugs.
if they are extremly clean and have a green tint to em that's always not a good sign. depending on how well you can look into the chambers the pistons would also be fairly clean.
Old Feb 11, 2011 | 04:18 PM
TheJunBuilt's Avatar
is ur carpet wet ?.. ur heater core could be leaking.?
Old Feb 11, 2011 | 04:20 PM
virgineg6's Avatar
lol! you waited like 10 minutes!
imma second "the bad headgasket" motion.
Old Feb 11, 2011 | 04:24 PM
Winlight's Avatar
you should check your math on that,lol
Old Feb 11, 2011 | 05:46 PM
Better yet, turn on the heater and smell for coolant
Old Feb 11, 2011 | 05:49 PM
beeseeries's Avatar
You said it's eating coolant and you know you have a bad headgasket...but you don't know what your problem is?
Old Feb 11, 2011 | 05:54 PM
grumblemarc's Avatar
The Grumpiest
No. He's not sure if it's a headgasket issue. Do a compression test.
Old Feb 11, 2011 | 07:31 PM
virgineg6's Avatar
my mistake didnt take a good look at it lol!
Old Feb 12, 2011 | 07:11 AM
bakomack's Avatar
yes the coolant is flowing, thats how I found out the car didnt have a t stat in it
they both have been replaced at one point or another because its a napa belt and the water pump is cleaner than the rest of the motor
will look into that today
I thought it was the heater core at first but everythings good and dry
no coolant smell
thing is it only eats water some times, idk why but I checked it 3 days in a row even after it got hot on me 1 time and its full of coolant.
it seems to only get hot if I floor it and take it to red line then let off the gas. thats about the only time I have the problem
Old Feb 12, 2011 | 07:34 AM
CrAzE191st's Avatar
im guessing small head gasket leak, id get a compression test
Old Feb 12, 2011 | 09:11 AM
beeseeries's Avatar
no coolant smell
Does your overflow fill up all the time?
Old Feb 12, 2011 | 11:34 AM
EFPhilly's Avatar
How about starting at the basics: did you bleed properly. I would take you cap off and look for bubbles man! If you see lots of bubbles and they don't stop then compression test time
Old Feb 13, 2011 | 12:16 AM
try a temp gauge ... see if it is really getting as hot as it is , i had a friend whos temp gauge would read way hot .. same kinda situation .. he bought a temp gauge .. wired it up ..so he could see actual number .. it would run at normal op temp but his gauge in his cluster was reading ubber high
ahhh to late u are lossing coolant .. so scratch that .. lol srry
Old Feb 13, 2011 | 12:45 AM
v8killaz's Avatar
headgasket or slow leak in pipes or something. ur loosing coolant. the pump is not bad. if ur losing coolant prob a leak or headgasket period
the previous owners replace everyhting because they prob knew it was overheating so they took the tstat out changed the water pump. but never did change the headgasket or figure out the problem. sorry im typing on a small laptop
Old Feb 13, 2011 | 03:09 AM
i now offically jumped on the head gasket bandwagon . lol
Old Feb 13, 2011 | 09:37 AM
EFPhilly's Avatar
Is the cap maintaining proper pressure, i.e. can ANY coolant be seen spilled right below the cap after driving.
You can always get a UV dye for your coolant and see where it is coming from, but if its an internal leak (headgasket) then this wouldn't do much good.
Old Feb 14, 2011 | 06:12 AM
CrAzE191st's Avatar
haha
caitb
Apr 26, 2015 06:22 PM
SIR EF9
Oct 27, 2012 10:34 AM
Amed Irizarry
21
Jul 21, 2011 07:50 PM
54
Nov 20, 2008 12:39 AM
Nocturnal
Dec 6, 2005 11:59 AM
