95 civic d15b7 seized?
Old Feb 10, 2011 | 06:44 PM
vegasmike80's Avatar
Icon2 95 civic d15b7 seized?
How easy should the crank pulley turn? I bought a 95 civic coupe for $400 but I can't turn the motor at all. I was pushing like crazy counterclockwise and it would turn. Would this mean the motor is seized?
Old Feb 10, 2011 | 07:00 PM
fonkernuckle's Avatar
Default Re: 95 civic d15b7 seized?
Sounds like it, did you check to see if the timing is still on cause if the timing belt broke or is missing a bunch of teeth, it could be that you are trying to turn the crankshaft/pistons which could be hitting open valves.
Old Feb 10, 2011 | 07:03 PM
94EG8's Avatar
Seagull Management
Could be, starter could be jamming up the flywheel too. (never seen on a honda but I have heard of it happening on other stuff) you did try this with the car in neutral right?
Old Feb 10, 2011 | 07:06 PM
yeah its in nuetral and the spark plugs out. Should i take the starter off and try it?
Old Feb 10, 2011 | 07:08 PM
94EG8's Avatar
Seagull Management
Sure why not? It's only 2 bolts.
Old Feb 10, 2011 | 07:17 PM
Former User's Avatar
You might also remove the three drive belts.
Old Feb 10, 2011 | 07:19 PM
no that crap didn't work. i guess its done.
motomoto413
Dec 11, 2013 06:40 PM
DanCan'tSwim
47
Aug 24, 2012 07:30 AM
ironiceghatch
Jun 30, 2012 06:43 AM
yeahsmitty
Jun 20, 2012 09:58 PM
MrRabbit87
23
Oct 30, 2008 02:49 PM
